Old 06-15-2018, 06:04   #1 (permalink)
srworld's Avatar
Member: 207734
Sonork: 100.1612198
Thanks Meter: 141
OPPO F7 after format restart problem
Operation : Reset Settings/Format FS [ v2.00 r4 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MTK USB Port (COM233)
MODE : BOOTROM
PORT : 233
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x000000E5
BROM : SecMode : SBC+SDA+SEL
BROM : BOOTROM
MODE : Oppo : F7 | Manual : Disabled
BROM : SLA
BROM : SLA Passed!
AGENT : Look for suitable BootChain in DA ...
AGENT : DA_BR_HIGH.bin
AGENT : Found MT6771
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : INFINITY
EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0
EMI : CNT : 000E
EMI : Init EMI from INTERNAL DB
EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00040000 [ 256.00 KB ]
DRAM: 0xC0000000 [ 3.00 GB ]
EMMC: 150100444836444D4205CA77901DB485
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : DH6DMB
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0xE8F800000 [ 58.24 GB ]
CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : EE9340D7D20DB5E0DDAB8F1AF5672FFC
DA : USB : HIGH-SPEED
Boot done!
Format Ok : USERDATA
Format Ok : CACHE
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:34
now give error
MODE : BOOTROM
PORT : 233
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
BROM : SLA
BROM : SLA Passed!
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 000E
DA : BOOT 2ND DA FAILED!
ERR : 0xC0070004
ERR : DA_HASH_MISMATCH
Error : Fail to init protocol!
Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Reconnect Power/Cable!
Old 06-15-2018, 07:21   #2 (permalink)
anoamocreative's Avatar
Member: 919549
Thanks Meter: 132
try this solution
http://forum.gsmhosting.com/vbb/13169404-post50040.html
Old 06-15-2018, 08:54   #3 (permalink)
princesaddam's Avatar
Member: 1010626
Sonork: using fb
Thanks Meter: 735
MODE : BOOTROM
PORT : 233
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
BROM : SLA
BROM : SLA Passed!
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 000E
EMMC:
Boot done!
Format Ok : CACHE
Done!
Elapsed: 00:00:34
now give error
MODE : BOOTROM
PORT : 233
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
BROM : SLA
BROM : SLA Passed!
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 000E
ERR : 0xC0070004
Hello,
here is the solution for u Readthis
The Following User Says Thank You to princesaddam For This Useful Post:
Old 06-15-2018, 11:25   #4 (permalink)
nahidroman's Avatar
Member: 2443283
Thanks Meter: 518
@srworld
Init MemoryTool
Select CACHE
press and hold CTRL key
Select USERDATA
Now both selected. Right click - Wipe/Erase partitions
Do.
Reboot device.
Old 06-15-2018, 15:59   #5 (permalink)
srworld's Avatar
Member: 207734
Sonork: 100.1612198
Thanks Meter: 141
Originally Posted by nahidroman View Post
@srworld
Init MemoryTool
Select CACHE
Select USERDATA
Do.
Reboot device.
thanx to all. my problem solved after use forced user format.
The Following User Says Thank You to srworld For This Useful Post:
Old 07-18-2018, 10:57   #6 (permalink)
Member: 294245
Sonork: 100.1602405
Thanks Meter: 115
@srworld
Init MemoryTool
Select CACHE
Select USERDATA
Do.
Reboot device.
Working Sloution But After Format Again
Old 09-04-2018, 11:20   #7 (permalink)
Member: 2643609
Sonork: zafar-01
Thanks Meter: 21
after reboot stark oppo logo agin
Page generated in 0.20853 seconds with 8 queries
