05-08-2021, 06:06 | #1 (permalink) |
No Life Poster Join Date: Jan 2008
Member: 681959 Status: Offline Thanks Meter: 106 | oppo f7 cph1819 help Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.23 Load IDBase v428174 Ok! Operation : Reset Settings/Format FS [ v2.23 ] Mode : FULL FACTORY ( WIPE + FRP ) 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM32) MODE : BOOTROM PORT : 32 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Sylvia TYPE : MODERN RAPHAEL BROM : MEID : BB7335BDBD55AC303A8E4EF1F01F8457 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Oppo : F7 | Manual : Enabled BROM : SOCID : D64F899499D0D9B9AED6AE3971170D1FB07A3D3B6239024148 49099F3C84D33B BROM : LOG : F0: 102B 0000 F3: 4000 0036 [0200] F3: 4000 0036 F7: 102D 0000 00: 1005 0000 F3: 4000 0036 [0200] F3: 4000 0036 F7: 102D 0000 01: 102A 0001 BROM : SLA : Sending Auth BROM : SLA : Auth accepted! BROM : SLA : CHALLENGE not used AGENT : Look for suitable BootChain in DA ... AGENT : DA_BR_HIGH.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_1 EMI : CNT : 0008 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : BOOT 2ND DA FAILED! ERR : 0xC0070004 ERR : DA_HASH MISMATCH Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Preloader [HW DEV] Info : EMI : DEV : MT6752 EMI : SRC : preloader_oppo6771.bin EMI : CNT : 0012 EMI : [00] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 512.00 MB ] EMI : [01] : eMMC : LP_DDR4X : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4.00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 150100444836444D42 : VEN : SAMSUNG | DEV : DH6DMB : RAM : [ 4.00 GB ] EMI : [03] : eMMC : DDR3 : ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 3.00 GB ] EMI : [04] : eMMC : DDR3 : ID : 150100525836344D42 : VEN : SAMSUNG | DEV : RX64MB : RAM : [ 4.00 GB ] EMI : [05] : eMMC : DDR3 : ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4.00 GB ] EMI : [06] : eMMC : LP_DDR4X : ID : 150100445636444D42 : VEN : SAMSUNG | DEV : DV6DMB : RAM : [ 4.00 GB ] EMI : [07] : eMMC : LP_DDR4X : ID : 150100334836434D42 : VEN : SAMSUNG | DEV : 3H6CMB : RAM : [ 6.00 GB ] EMI : [08] : eMMC : LP_DDR4X : ID : 150100335636434D42 : VEN : SAMSUNG | DEV : 3V6CMB : RAM : [ 6.00 GB ] EMI : [09] : eMMC : DDR3 : ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ] EMI : [0A] : eMMC : LP_DDR4X : ID : 150100444836444142 : VEN : SAMSUNG | DEV : DH6DAB : RAM : [ 4.00 GB ] EMI : [0B] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ] EMI : [0C] : eMMC : LP_DDR4X : ID : 13014E53304A394B39 : VEN : MICRON | DEV : S0J9K9 : RAM : [ 4.00 GB ] EMI : [0D] : eMMC : LP_DDR4X : ID : 13014E53304A394438 : VEN : MICRON | DEV : S0J9D8 : RAM : [ 4.00 GB ] EMI : [0E] : eMMC : LP_DDR4X : ID : 450100444134313238 : VEN : SANDISK | DEV : DA4128 : RAM : [ 4.00 GB ] EMI : [0F] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 4.00 GB ] EMI : [10] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ] EMI : [11] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] Operation : Write Flash [ v2.23 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :23 [FL] : Set : preloader_oppo6771.bin [FL] : Set : recovery.img [FL] : Set : md1img.img [FL] : Set : spmfw.img [FL] : Set : scp.img [FL] : Set : scp.img [FL] : Set : sspm.img [FL] : Set : sspm.img [FL] : Set : cam_vpu1.img [FL] : Set : cam_vpu2.img [FL] : Set : cam_vpu3.img [FL] : Set : lk.img [FL] : Set : lk.img [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : odmdtbo.img [FL] : Set : tee.img [FL] : Set : tee.img [FL] : Set : odm.img [FL] : Set : vendor.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0x1EE2237D4 [ 7.72 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM32) MODE : BOOTROM PORT : 32 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Sylvia TYPE : MODERN RAPHAEL BROM : MEID : BB7335BDBD55AC303A8E4EF1F01F8457 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Oppo : F7 | Manual : Disabled BROM : SOCID : D64F899499D0D9B9AED6AE3971170D1FB07A3D3B6239024148 49099F3C84D33B BROM : LOG : F0: 102B 0000 F3: 4000 0036 [0200] F3: 4000 0036 F7: 102D 0000 00: 1005 0000 F3: 4000 0036 [0200] F3: 4000 0036 F7: 102D 0000 01: 102A 0001 BROM : SLA : Sending Auth BROM : SLA : Auth accepted! BROM : SLA : CHALLENGE not used AGENT : Look for suitable BootChain in DA ... AGENT : DA_BR_HIGH.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6752 EMI : SRC : preloader_oppo6771.bin EMI : CNT : 0012 EMI : [00] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 512.00 MB ] EMI : [01] : eMMC : LP_DDR4X : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4.00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 150100444836444D42 : VEN : SAMSUNG | DEV : DH6DMB : RAM : [ 4.00 GB ] EMI : [03] : eMMC : DDR3 : ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 3.00 GB ] EMI : [04] : eMMC : DDR3 : ID : 150100525836344D42 : VEN : SAMSUNG | DEV : RX64MB : RAM : [ 4.00 GB ] EMI : [05] : eMMC : DDR3 : ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4.00 GB ] EMI : [06] : eMMC : LP_DDR4X : ID : 150100445636444D42 : VEN : SAMSUNG | DEV : DV6DMB : RAM : [ 4.00 GB ] EMI : [07] : eMMC : LP_DDR4X : ID : 150100334836434D42 : VEN : SAMSUNG | DEV : 3H6CMB : RAM : [ 6.00 GB ] EMI : [08] : eMMC : LP_DDR4X : ID : 150100335636434D42 : VEN : SAMSUNG | DEV : 3V6CMB : RAM : [ 6.00 GB ] EMI : [09] : eMMC : DDR3 : ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ] EMI : [0A] : eMMC : LP_DDR4X : ID : 150100444836444142 : VEN : SAMSUNG | DEV : DH6DAB : RAM : [ 4.00 GB ] EMI : [0B] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ] EMI : [0C] : eMMC : LP_DDR4X : ID : 13014E53304A394B39 : VEN : MICRON | DEV : S0J9K9 : RAM : [ 4.00 GB ] EMI : [0D] : eMMC : LP_DDR4X : ID : 13014E53304A394438 : VEN : MICRON | DEV : S0J9D8 : RAM : [ 4.00 GB ] EMI : [0E] : eMMC : LP_DDR4X : ID : 450100444134313238 : VEN : SANDISK | DEV : DA4128 : RAM : [ 4.00 GB ] EMI : [0F] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 4.00 GB ] EMI : [10] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ] EMI : [11] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 150100444836444D42052DA8C6F4B40F EMMC: VEN : SAMSUNG | OEM : 01 | DEV : DH6DMB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : E0833DB3925647A41EC9C0CE616EC1BE DA : USB : HIGH-SPEED Boot done! [FL] : COMBO scatter! Update settings to eMMC [FL] : Set : preloader_oppo6771.bin [FL] : Set : recovery.img [FL] : Set : md1img.img [FL] : Set : spmfw.img [FL] : Set : scp.img [FL] : Set : scp.img [FL] : Set : sspm.img [FL] : Set : sspm.img [FL] : Set : cam_vpu1.img [FL] : Set : cam_vpu2.img [FL] : Set : cam_vpu3.img [FL] : Set : lk.img [FL] : Set : lk.img [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : odmdtbo.img [FL] : Set : tee.img [FL] : Set : tee.img [FL] : Set : odm.img [FL] : Set : vendor.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000004188000 Erase : 0x0000000006888000 : 0x0000000001500000 Erase : 0x0000000009D88000 : 0x0000000006000000 Erase : 0x0000000011000000 : 0x0000000000800000 Erase : 0x0000000014800000 : 0x0000000000200000 Erase : 0x0000000014D00000 : 0x000000000C000000 Erase : 0x0000000024D00000 : 0x0000000390B00000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader backup copy ... Update bootloader backup copy Ok! Write : RECOVERY FAIL : SEC : IMGHDR TYPE MISMATCH Write : MD1IMG Write : SPMFW Write : SCP1 Write : SCP2 Write : SSPM_1 Write : SSPM_2 Write : CAM_VPU1 Write : CAM_VPU2 Write : CAM_VPU3 Write : LK Write : LK2 Write : BOOT FAIL : SEC : IMGHDR TYPE MISMATCH Write : LOGO Write : ODMDTBO FAIL : SEC : IMG TYPE MISMATCH Write : TEE1 Write : TEE2 Write : ODM Write : VENDOR Write : SYSTEM Write : CACHE Write : USERDATA Ultra : OK! [ All failed parts successfully flashed ] SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:04:37 Reconnect Power/Cable! |
