11-18-2018, 10:58 | #1 (permalink) |
Freak Poster Join Date: Aug 2016 Location: pakistan
Member: 2607653 Status: Offline Sonork: family members Thanks Meter: 177 | Oppo F9 CPH1823 Succesfully Read Firmware Done By Cm2 MT2 v2.02 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.02 Load IDBase v11861 Ok! Operation : Memory Tool Init [ v2.02 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... Card found : Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.02 Load IDBase v11861 Ok! Operation : Read Firmware [ v2.02 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM140) MODE : BOOTROM PORT : 140 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+SEL BROM : BOOTROM MODE : Oppo : F7 | Manual : Disabled BROM : SLA BROM : SLA Passed! AGENT : Look for suitable BootChain in DA ... AGENT : DA_BR_HIGH.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 EMI : CNT : 000E EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 150100444836444142021BFDC2CE95C7 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : DH6DAB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 15304D5DE3B5E4154DBBA3105EA2B928 DA : USB : HIGH-SPEED Boot done! Patch Level : O11019 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-08-05 Product Manfct : OPPO Build Time : 1538297688 Product Brand : OPPO Product Model : CPH1823 Product Info : CPH1823 Product Device : CPH1823 Product Name : CPH1823 SW OTA Version : CPH1823EX_11.A.08_0080_201809301620 Display ID : CPH1823EX_11_A.08_180930 Kernel Info : 4.4.95-G201809301620 MT6771__OPPO__CPH1823__8.1.0__CPH1823EX_11_A.08_18 0930__O11019__CPH1823 Read : preloader.bin Read : recovery.img Read : oppo_custom.img Read : persist.img ExtSparse : Compression ratio : 100% Read : proinfo.img Read : md1rom.img Read : spmfw.img Read : tinysys-scp.bin Read : tinysys-sspm.bin Read : cam_vpu1.img Read : cam_vpu2.img Read : cam_vpu3.img Read : nvram.bin Read : lk.bin Read : boot.img Read : logo.bin Read : odmdtbo.img Read : tz.img Read : odm.img ExtSparse : Compression ratio : 100% Read : vendor.img ExtSparse : Compression ratio : 31% Read : system.img ExtSparse : Compression ratio : 3% Read : cache.img Read : userdata.img FW Size : 5.56 GB Android Info saved : _Android_info.txt Scatter : MT6771_Android_scatter.txt Saved to : C:\Users\abc\Desktop\MT6771__OPPO__CPH1823__8.1.0_ _CPH1823EX_11_A.08_180930__O11019__CPH1823\ Done! Elapsed: 00:10:44 |
The Following 10 Users Say Thank You to jonny12345 For This Useful Post: |
11-18-2018, 13:00 | #3 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Earth
Member: 593876 Status: Offline Thanks Meter: 302 | after Expire Activation show Load IDBase v11861 to Load IDBase v111571 what is this? and why? @JayDi Now: Card found : 6CDF41BF , v0137 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.02 Load IDBase v111571 Ok! Update configuration ... Update Ok! Load IDBase v111571 Ok! |
The Following 2 Users Say Thank You to mcclinic For This Useful Post: |
11-18-2018, 14:24 | #6 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
To check Expiry date click here https://www.infinity-box.com/doc.php?id=17 | |
11-18-2018, 15:28 | #7 (permalink) | |
No Life Poster Join Date: Mar 2012 Location: India
Member: 1728736 Status: Offline Sonork: 100.1615042 Thanks Meter: 1,098 | Quote:
My Idbase also sow Code: Card found : B4682B40 , v0137 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.02 Load IDBase v111571 Ok! Update configuration ... Update Ok! Load IDBase v111571 Ok! but my support till active Code: Token - Type: Infinity-Box/Dongle - Account Status: Active - Hardware Status: Ok Services - Activation 1: Infinity-Box/Dongle; S/N: B4682B40; Firmware Version: 0137; Registered: 22-Jan-2011; Expired: 22-Aug-2019; Support: Active - Activation 2: Infinity SM - More Services may be active but not listed | |
The Following User Says Thank You to .:Sanjh Phoenix:. For This Useful Post: |
11-18-2018, 17:32 | #10 (permalink) |
Member: 593876 Status: Offline Thanks Meter: 302 | Token - Type: Infinity-Box/Dongle - Account Status: Active - Hardware Status: Ok Services - Activation 1: Infinity-Box/Dongle; S/N: 6CDF41BF; Firmware Version: 0137; Registered: 17-Jun-2017; Expired: 17-Nov-2018; Support: Expired; Support Renew 1 year Support Renew 2 years - More Services may be active but not listed -Support Expire Means? LoadIDBase will Stop? DL also? |
The Following User Says Thank You to mcclinic For This Useful Post: |
11-20-2018, 04:14 | #13 (permalink) | |
http://forum.gsmhosting.com/vbb/f296.../#post13422722 http://forum.gsmhosting.com/vbb/f296.../#post13422854 http://forum.gsmhosting.com/vbb/f296.../#post13422927 | |
11-24-2018, 10:40 | #14 (permalink) |
Junior Member Join Date: Feb 2014 Location: Las Pinas City (mentro manila)
Member: 2119562 Status: Offline Thanks Meter: 2 | about this unit(oppo f9) yes there is no issue or problem when you read it or making a back up... the problem is when you use CM2m2 to remove password and FRP it will become boot loop... i already try to program the unit using cm2m2 but sad to say it still error DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : EMI : SRC : EMI : CNT : 0000 EMI : Init EMI from INTERNAL DB DA : SETUP EMI PARAMS FAILED! ERROR : ERROR Error : Fail to init protocol! Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device! Reconnect Power/Cable! hope you could also help us thank you... |
