05-14-2008, 09:10 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: pakistan Age: 49
Member: 232607 Status: Offline Sonork: 100.1585040 Thanks Meter: 260 | Orange Tr1 Device: Orange-Tokyo Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: unlock unlock method: standard Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6219:8B02:8B01]... CPU: MT6219 CPU: MT6226MA detected chip: 0031:A994:B95C boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: SL900A_UKORANGE_PCB01_GPRS_MT6226M_S01.SL900A_05C_ W06_08_MP_V72.BIN ver. sw2: SL900A.05C.W06.08.MP.V72, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[SL900A_UKORANGE_PCB01_GPRS_MT6226M_S01.SL900A_05C_ W06_08_MP_V72.BIN]]... file saved: C:\Program Files\InfinityBox\MModule\backup_eeprom[SL900A_UKORANGE_PCB01_GPRS_MT6226M_S01.SL900A_05C_ W06_08_MP_V72.BIN]_20080514-005709.B0E.bin flash: 89881500010001:89881500000000 Backup required data Done Patch required data... detection procedure, wait... error: phone is not locked or unknown eeprom Patch required data Fail Finished, time used: 374 sec Remove/Install battery now ! MASTER CODE STILL LOCKED NOW IT IS SLECTED TRI AND UNLOCK METHOD STANDARD COM3 [VCP0] selected Device: Orange-TR1 Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: unlock unlock method: standard Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6219:8B02:8B01]... CPU: MT6219 CPU: MT6226MA detected chip: 0031:A994:B95C boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: SL900A_UKORANGE_PCB01_GPRS_MT6226M_S01.SL900A_05C_ W06_08_MP_V72.BIN ver. sw2: SL900A.05C.W06.08.MP.V72, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[SL900A_UKORANGE_PCB01_GPRS_MT6226M_S01.SL900A_05C_ W06_08_MP_V72.BIN]]... file saved: C:\Program Files\InfinityBox\MModule\backup_eeprom[SL900A_UKORANGE_PCB01_GPRS_MT6226M_S01.SL900A_05C_ W06_08_MP_V72.BIN]_20080514-010453.B0E.bin flash: 89881500010001:89881500000000 Backup required data Done Patch required data... detection procedure, wait... detection procedure completed Patch required data Done Special operation... detecting additional parameters... ................................. flash: 89881500010001:89881500000000 flash: 89881500010001:89881500000000 Write: area 0/1 ............................... additional parameters detected Ok Special operation Done Write... flash: 89881500010001:89881500000000 Write: eeprom Write Done Finalization... Finalization Done Finished, time used: 190 sec Remove/Install battery now ! ITS UNLOCK 100%%%% |
12-01-2008, 08:15 | #2 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | i did as you said but still "master code" COM8 [Serial2] selected module v2.40 Device: Orange-TR1 Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "user code" unlock method: standard Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6219:8B02:8B01]... CPU: MT6219 detected CPU: MT6226MA chip: 0031:6F9E:027D boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: SL900A_UKORANGE_PCB01_GPRS_MT6226M_S01.SL900A_05C_ W06_08_MP_V72.BIN ver. sw 2: SL900A.05C.W06.08.MP.V72, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[SL900A_UKORANGE_PCB01_GPRS_MT6226M_S01.SL900A_05C_ W06_08_MP_V72.BIN]... file saved: C:\Program Files\InfinityBox\MModule\eeprom[SL900A_UKORANGE_PCB01_GPRS_MT6226M_S01.SL900A_05C_ W06_08_MP_V72.BIN]_20081129-135114.B0E.bin flash: 89881500010001:89881500000000 Backup required data Done Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done Special operation ... Special operation Done write ... flash: 89881500010001:89881500000000 Write: eeprom write Done Finalization ... Finalization Done Finished, time used: 250 sec Remove/Install battery now ! |
12-28-2008, 19:25 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | |
05-26-2009, 15:12 | #8 (permalink) |
No Life Poster Join Date: Jun 2004 Location: China Age: 46
Member: 68392 Status: Offline Sonork: 100.100701 Thanks Meter: 658 | COM7 selected module v2.82 Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6219:8B02:8B01]... CPU: MT6219 high speed boot On chip: 0031:00C2:7EEA status: FF detected CPU: MT6226MA Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226M,E02 Date: 2005.04.12 Version: 1.0 Version: SL900A.05C.W06.08.MP.V72 Version: ESL6227_05C_HW detecting structure #2... done 60 byte(s) read imei: 35524701019994 connection Ok detecting structure #1... done 208 byte(s) read reading data #2... Phone lock: Off Network lock: On Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off NP code: 91299910/19929901 locked to: FFF-FF SP code: 0000000000003344/0000000000003344 CP code: FFFFFFFFFFFF0000/FFFFFFFFFFFF0000 Phone code: 0000000000000000 Finished, time used: 41 sec Remove/Install battery now ! |
The Following User Says Thank You to Kanwalgee For This Useful Post: |
Orange TR1 Unlock | Amorphes | Infinity-Box | 8 | 08-13-2007 09:16 |
plz help me how to unlock Orange TR1 | qayyoom1 | Infinity-Box | 7 | 07-07-2007 19:49 |
Special update for UK market: Orange TR1 | InfinitySupport | Infinity-Box | 11 | 06-25-2007 22:49 |
June 21st - ET-BoX v1.39 Released - Orange TR1 Supported | .:ET-BoX.net:. | ET-BoX | 3 | 06-22-2007 00:17 |
Orange TR1 | shahzaadbutt | Various | 2 | 06-12-2007 14:59 |
