Old 12-20-2008, 08:05   #1 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 569
Alcatel E221 Successfully Unlock
hi
Alcatel E221 Successfully Unlock...............thanks infinity team
COM13 [VCP0] selected
module v1.30
Device: Alcatel-E221
"advanced chip detection" active
Action: unlock
Checking data, wait...
Boot ...
Press Power button now !
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Check connection ...
Check connection done
Set baud ...
812500
Set baud done
Check hardware ...
flash: 012A7E2A242A00:54000000000000
flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb
Check hardware done
Read data ...
reading Alcatel-E221_eeprom_calibration-1...
file saved: C:\Program Files\InfinityBox\HModule\Alcatel-E221_eeprom_calibration-1_20081220-114409.80E.bin
Read data done
Check data ...
Check data done
Write ...
Write: simlock
Write done
Finished, time used: 76 sec
Remove/Install battery now !
The Following User Says Thank You to zeerik For This Useful Post:
Old 12-20-2008, 08:58   #2 (permalink)
zinoubinabil's Avatar
Member: 84268
Sonork: 100.114149
Thanks Meter: 2,569
Thank you very much for test report !
Each test report with attached logs is very important for us so we can see how is Infinity-Box
software works and what is possible problems (so we will be able to fix it) and successfully done work.
Old 12-20-2008, 09:53   #3 (permalink)
Redtan_70's Avatar
Member: 785142
Sonork: 100.1606160
Thanks Meter: 177
yes sir , we need that logs for as user..........
Old 12-23-2008, 22:20   #4 (permalink)
glontz's Avatar
Member: 16269
Sonork: 1604924
Thanks Meter: 62
what cablu use ? i try whit elle, e256 not work :| ?
Old 12-24-2008, 19:36   #5 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information)
Here is information how to build your own cable:
http:///vbb/showthread.php?t=342807
Old 12-27-2008, 12:05   #6 (permalink)
Member: 322417
Thanks Meter: 940
Another E221 Alcatel Unlocked like sharm
Hear Log
COM8 [VCP2] selected
module v1.30
Action: unlock
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Set baud ...
115200
Set baud done
Check hardware ...
Check hardware done
Read data ...
file saved: C:\Program Files\InfinityBox\HModule\Alcatel-E221_eeprom_calibration-1_20081227-120321.80E.bin
Read data done
Check data ...
Check data done
Write ...
Write: simlock
Write done
Finished, time used: 80 sec
Regards Infinity Team
The Following User Says Thank You to Formingus For This Useful Post:
Old 12-27-2008, 12:47   #7 (permalink)
Member: 322417
Thanks Meter: 940
@Glontz
Actually e256 don't work for me too
I made cable for e101 when unlock one set then use same cable and work fine
Regards
Old 12-27-2008, 12:49   #8 (permalink)
Member: 322417
Thanks Meter: 940
@Glontz
Regards
Old 01-04-2009, 03:01   #9 (permalink)
_iskor_'s Avatar
Member: 94806
Thanks Meter: 19
e221 unlock succesfully
Action: unlock
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Set baud ...
115200
Set baud done
Check hardware ...
Check hardware done
Read data ...
file saved: C:\Program Files\InfinityBox\HModule\Alcatel-E221_eeprom_calibration-1_20090104-095849.80E.bin
Read data done
Check data ...
Check data done
Write ...
Write: simlock
Write done
Finished, time used: 79 sec
The Following 2 Users Say Thank You to _iskor_ For This Useful Post:
Old 01-04-2009, 13:17   #10 (permalink)
Member: 130995
Action: unlock
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Set baud ...
115200
Set baud done
Check hardware ...
Check hardware done
Read data ...
Read data done
Check data ...
Check data done
Write ...
Write: simlock
Write done
so we can see how is Infinity-Box software works and what is
Old 01-04-2009, 13:40   #11 (permalink)
_iskor_'s Avatar
Member: 94806
Thanks Meter: 19
keep it up infinity team.
thanks for great support
Old 08-01-2009, 18:22   #12 (permalink)
oscarjr85's Avatar
Member: 978651
Sonork: 1672421
Thanks Meter: 85
Friend went well but said there was no network in Spain is to be done in this case?
greetings
oscarjr
Old 01-06-2016, 12:03   #13 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
Alcatel OT-E221 Unlock Successfull
Alcatel E221 Sucessfuly Unlock By Infinity Shakeel Communication Infinity-Box 2 03-19-2024 10:33
alcatel e221,e227 unlock succesffuly with infinity-box KARIM GSM-ZONE Infinity-Box 21 04-02-2012 20:42
alcatel s521a successfully unlocked ::: USER REPORT THX ::: luinaranjo PolarBox 3 0 02-23-2009 22:43
Alcatel s920 successfully unlocked with polar box dasuza PolarBox 3 3 10-28-2008 21:16
Alcatel e221 100% unlocked godwin Infinity-Box 0 04-15-2008 11:13
Page generated in 0.33346 seconds with 9 queries
