07-17-2011, 21:24 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Fast-Code™ MBKPHONE Ltd Age: 38
Member: 269035 Status: Offline Sonork: 1,618,0786 Thanks Meter: 301 | OT505 dead after flash I TRY TO UNLOCK FIRST THEN PHONE RESTART ON STARTUP AND I FLASH NOW PHONE IS DEAD ANY SOLUTION PLEASE?? I FLASHED WITH 505X-2EVRFR1-26F_XP26DP20_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI _08A_W08_36_SP1_V34_2010-09-09_En_Fr_Es_It_De.B0M.bin AND 505X-2CLHCH1-26F_XP26DV25_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI _08A_W08_36_SP1_V34_2010-09-09_En_Fr_Es_It_De.B0M.bin COM1 [Serial0] selected module v3.63 Device: Alcatel-505X Checking data, wait... advanced flash detection enabled Action: write flash write: Firmware 505X-2EVRFR1-26F_XP26DP20_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI _08A_W08_36_SP1_V34_2010-09-09_En_Fr_Es_It_De.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:9817:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... slowest Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.E79E5 E52.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_16500F8B].rpl ==================== New firmware found (v.3.63, database date: 20.10.2010): JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished TCL-ID detection... TCL-ID detection done device-id: E79E5E52 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, 8B0F5016 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 26G provider: 505X-2ARGRE1 customization: CP26CR22 customization: XP26CR22 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35777003757743 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... firmware patch (sp-lock #1)... not required firmware patch (sp-lock #2)... not required Special operation Done ====> Write ... usb bootloader (file) is absent startup code area #1 check... rpl file not found: C:\Program Files\InfinityBox\MModule\id.E79E5E52.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_0DAE626C].rpl rpl file not found: C:\Program Files\InfinityBox\MModule\id.E79E5E52._JRD23_08A_P CB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V34.BIN_ 0DAE626C_.rpl rpl file not found: C:\Program Files\InfinityBox\MModule\backup_security\id.E79E5 E52.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_0DAE626C].rpl rpl file not found: C:\Program Files\InfinityBox\MModule\backup_security\id.E79E5 E52._JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08 _36_SP1_V34.BIN_0DAE626C_.rpl ==================== warning: unknown firmware: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_0DAE626C Unknown firmware found (v.3.63, database date: 20.10.2010), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed You can flash phone now but can not finalize it, in most cases phone CAN NOT power-on. Do you want to continue anyway ? file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-505X_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08 _36_SP1_V34__system_log_E79E5E52_16500F8B_20110717-153606.B0X.bin Area: Firmware flash: 98000300000001:2BEA0000000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected relocation table detected name table[00] #7000000 detected customization: CP26DP20 customization name adjusted customization: CP26DP20 customization name adjusted customization detected: CP26DP20 customization: CP26DP20 customization: XP26CR22 error: can't calculate security area (sec info, cust), existing data will be used Check support area for updates ! security area (sec info, cust) calculation done security area (sec info, hash) calculation... version is not found in database: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN use default security area (sec info, hash) pattern max address is too big, should be recalculated: 08BF8000->086CC310 ..................security area (sec info, hash) detecting size... error: security area (sec info, hash) size is incorrect: 01C0 instead of 0374 Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-505X_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08 _36_SP1_V34__system_log_E79E5E52_16500F8B_20110717-160009.B0X.bin Finished, time used: 25 min 22 sec Remove/Install battery now ! |
07-17-2011, 21:39 | #2 (permalink) |
Member: 269035 Status: Offline Sonork: 1,618,0786 Thanks Meter: 301 | [IMG] Uploaded with ImageShack.us[/IMG] |
07-18-2011, 20:59 | #3 (permalink) |
Member: 269035 Status: Offline Sonork: 1,618,0786 Thanks Meter: 301 | COM1 [Serial0] selected module v3.96 Device: Alcatel-505X Checking data, wait... advanced flash detection disabled Action: write flash security area calculation disabled write: Firmware 505X-2EVRFR1-26F_XP26DP20_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI _08A_W08_36_SP1_V34_2010-09-09_En_Fr_Es_It_De.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:9817:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba T 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... slowest Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 record #1 is damaged, recalculation required rom info detection finished TCL-ID detection... TCL-ID detection done device-id: E79E5E52 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, 6C62AE0D code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 26F provider: 505X-2CLHCH1 customization: CP26DV25 customization: XP26DV25 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is invalid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35777003757743 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... firmware patch (sp-lock #1)... not required firmware patch (sp-lock #2)... not required Special operation Done ====> Write ... file saved: C:\InfinityBox\MModule\backup_security\Alcatel-505X_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08 _36_SP1_V34__system_log_E79E5E52_0DAE626C_20110718-145139.B0X.bin Area: Firmware flash: 98000300000001:2BEA0000000000 Write: Firmware Write Done ====> Finalization ... Finalization Done file saved: C:\InfinityBox\MModule\backup_security\Alcatel-505X_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08 _36_SP1_V34__system_log_E79E5E52_0DAE626C_20110718-151338.B0X.bin Finished, time used: 22 min 51 sec Remove/Install battery now ! phone still dead any solution? |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
5110 5.24 locked all 4 locks after unlocking... | MCG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-07-2000 22:24 |
