07-14-2011, 01:13 | #2 (permalink) |
No Life Poster Join Date: Feb 2011 Location: Guatemala
Member: 1526099 Status: Offline Sonork: 100.1579632 Thanks Meter: 84 | yes is posible...add me to msn and send infomation for unlock celmaster2(at)gmail(dot)com |
The Following User Says Thank You to Celmaster2 For This Useful Post: |
07-17-2011, 01:45 | #3 (permalink) |
Junior Member Join Date: Aug 2010 Location: Tecamac Edo. de mexico Age: 36
Member: 1359030 Status: Offline Thanks Meter: 5 | Module Chinesse Miracle, Autodetect 6205-6239 writing (imei default inside firmware) code NP 12345678 Besos. Code: COM47 [VCP0] selected modulo v3.25 Servicio: Autodetect 6205-6239 NOR Checkeando datos, espere... Habilitada la deteccion avanzada del chip Action: "repair imei" Canal de escritura de imei: imei #1 (default imei inside firmware) Nuevo imei: 354689041309875 ====> Boot ... Mantenga Presionado el boton Power ! error: boot initialization step #3 failed: 19200 fixed Conectando, espere... Iniciando [6223:8A05:8A00]... CPU: MT6223 alta velocidad de boot On chip: 0011:7F51:000C status: FF Tamaño del boot packet: 0400 Deje de presionar el boton power ahora ! Boot Done ====> Iniciar ... detecting chip #00 in region #00... Flash 2088C4FFFF0086:2088C400000000 Flash ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... Flash 2088C4FFFF0086:2088C400000000 Flash ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... Flash 2088C4FFFF0086:2088C400000000 Flash ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... Flash 2088C4FFFF0086:2088C400000000 Flash ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 numero de flash chip/regiones detectadas: 04/01 Iniciar Done ====> Seleccionar velocidad ... 921600 Seleccionar velocidad Done ====> Iniciar bootcode ... Iniciar bootcode Done ====> Comprobar la integridad del firmware ... device parameters detection in progress... detecting chip #00 in region #00... Flash 2088C4FFFF0086:2088C400000000 Flash ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... Flash 2088C4FFFF0086:2088C400000000 Flash ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: 2C0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 numero de flash chip/regiones detectadas: 01/01 Tamaño total de la region flasheada: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\ChineseMiracle\backup_security\id.DDF92A9C.[CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223_S00.C1012_4_0_0X01209_TELEFONICA_MX.BIN_552E1936].rpl ==================== New firmware found (v.3.25, database date: 24.10.2010): CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223_S00.C1012_4_0_0X01209_TELEFONICA_MX.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Leer full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished device-id: DDF92A9C rom info ver: 07 sw version: CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223_S00.C1012_4_0_0X01209_TELEFONICA_MX.BIN project-id: C1012_4.0_0x01209_TELEFONICA_MX, 36192E55 code offset: 00000000 ffs offset/size [02]: 00C00000/00400000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00C00000 standard ffs/eeprom offset confirmed: 00C00000 detecting ffs/eeprom size... ffs/eeprom size: 00400000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00C00000-00FFFFFF firmware area: 00000000-00BFFFFF detectando startup code area #2... ................................................................................................................................................................................................................................................................ startup code area #2 is absent startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Comprobar la integridad del firmware Done ====> Comprobar el contenido del firmware ... Comprobar el contenido del firmware Done ====> Backup de datos requeridos ... Flash 2088C4FFFF0086:2088C400000000 Backup de datos requeridos Done ====> Revisión de datos requeridos ... detecting ffs/eeprom structure pass 2... ............................ ffs/eeprom: detect std location pass #1... ................................................ ffs/eeprom: detect ext location pass #1... ............................................. ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok element #2 imei default found: FFFFFFFFFFFFFF Revisión de datos requeridos Done ====> Operacion Especial ... Operacion Especial Done ====> Escribir ... Flash 2088C4FFFF0086:2088C400000000 Flash 2088C4FFFF0086:2088C400000000 Escribir imei Escribir Done ====> Finalizado ... FFS formatting... Flash 2088C4FFFF0086:2088C400000000 Finalizado Done Archivo guardado: C:\Archivos de programa\InfinityBox\ChineseMiracle\backup_security\CELLONSZ23C_09A_GEMINI_PCB01_GPRS_MT6223_S00.C1012_4_0_0X01209_TELEFONICA_MX__system_log_DDF92A9C_552E1936_20110716-193350.B0X.bin Finalizado, tiempo usado: 2 min 31 sec Quite/coloque la bateria ahora ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
Is it possible to use the Nokia 6150 with the IR Port of a Toshiba Laptop? | telefonman | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-13-2000 20:06 |
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? | MyKe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-26-1999 14:31 |
