11-01-2016, 06:33 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: pakistan
Member: 898041 Status: Offline Sonork: 100.1593459 Thanks Meter: 549 | pettron lock read problem (6580) with cm2 Start at : [11/1/2016 / 10:23:06 AM] Operation : Read Pattern/DP Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847316505072B308A0E3355 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A483847316505072B308A0E3355 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x3FA54DA4992DF0FAAD9FCB97B700A8CB INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... [Info] : PatternLock Not Set! [Info] : DP Lock not set! |
The Following User Says Thank You to shamshad quresh For This Useful Post: |
11-01-2016, 06:56 | #2 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Hello, Use Reset UserLock (data will be safe) post result/logs..... |
The Following 2 Users Say Thank You to syed tuqeer For This Useful Post: |
01-05-2017, 15:25 | #4 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Operation : Check / Read Info [ v1.58 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 86 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100463732324D42003928DAC8730D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM227 [eMMC] : FLASH_CID : 150100463732324D42003928DAC8730D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x04E4529929B250A7CE11D9E04824924E INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Karbonn ProdName : Karbonn_K9_Viraat ProdModel : K9 Viraat Device : K9_Viraat AndroidVer: 6.0 MTKxCPU : MT6580 MTKxPRJ : alps-mp-m0.mp1-V2.34_vsun6580.we.m_P2 SECURITY : IMEI_SW [1] : 911535XXXXXXXXX IMEI_SW [2] : 911535XXXXXXXXX BTMAC Addr : BEA94XXXXXXX WiFi MAC : 98109XXXXXXX MODEM : BaseBand : MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V57_1_wg_n EXTRA : LCD : Not info available :( LCD Res : 1280x720 TOUCH [0] : ft3427_zaw875 CAM [0] : s5k4h5yc_mipi_raw CAM [1] : s5k5e2ya_mipi_raw CAM [2] : gc2755_mipi_raw CAM [3] : gc2355_mipi_raw CAM [4] : gc5005_mipi_raw CAM [5] : gc2365_mipi_raw MODEM : vsun6580_v5501A_dual900_18band LOCALE : en_US en_IN en_GB hi_IN in_ID cs_CZ de_DE es_ES es_US fr_CA hr_HR it_IT sw_TZ hu_HU pl_PL pt_PT ro_RO sk_SK sl_SI sr_RS tr_TR el_GR bg_BG ru_RU ka_GE ur_PK ar_EG fa_IR bn_BD my_MM th_TH vi_VN Done! Elapsed: 00:00:21 Reconnect Power/Cable! Operation : Read Pattern/DP Lock [ v1.58 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 86 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100463732324D42003928DAC8730D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM227 [eMMC] : FLASH_CID : 150100463732324D42003928DAC8730D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x04E4529929B250A7CE11D9E04824924E INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... [Info] : PatternLock Not Set! [Info] : DP Lock not set! Done! Elapsed: 00:00:18 Reconnect Power/Cable! Operation : Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc] [ v1.58 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 86 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100463732324D42003928DAC8730D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM227 [eMMC] : FLASH_CID : 150100463732324D42003928DAC8730D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x04E4529929B250A7CE11D9E04824924E INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! LSSDB Ok! LSSWL Ok! LSSSH Ok! LSSNG Ok! LSSNP Ok! Security Settings : Clear Ok! [Info] : That feature NOT RESET "PRIVACY PASSWORD LOCK"! Use separate button! [Info] : That feature NOT RESET "FRP/GoogleLOCK"! Use separate "FRP" reset! [Info] : If phone stuck on "Logo" : 1. Wait 2-3 minutes. Power Off phone by long press "Power" button 2. Power On phone again 3. Or wait up to 3-7 minutes, until phone start by itself 4. Also recommended reboot phone twice before start use it Done! Elapsed: 00:00:26 Reconnect Power/Cable! Now Hang At Logo/BootLoop & Data Is Very Important. What Should I Do Now Please? |
01-05-2017, 19:15 | #5 (permalink) |
Insane Poster Join Date: Jun 2008
Member: 794019 Status: Offline Thanks Meter: 31 | backup full emmc first, bin format on flash tab, then you can try to fix it while you have the whole emmc content as backup. when the phone is alive you can try to reflash it with the backup file to restore its content, but i didnt guarantee when you write it the phone isnt going back to bootloop state because you read it while the phone is on bootloop state. but if the data is THAT important, your priority is to backup the whole emmc content first. then you can try to fix it. goodluck. |
