11-27-2009, 18:20 | #1 (permalink) |
Insane Poster Join Date: Sep 2007
Member: 587123 Status: Offline Thanks Meter: 7 | Pinfinder can't be detected :( I have a problem with my pinfinder it was working very good but the day before yesterday i try to connected to unlock utstarcom 1208 but pinfinder now can not be detected and i do not why i install againg all the software and drivers and always drop the same problem here you can see some images. Now i do not know where is the problem i do not know if my infinity box is the problem or just pinfinder? Here you can see that infinity box is at COM19: But Pinfinder can not be detected Drivers are ok but as i told you before pinfinder was working very good just the day before yesterday dropme that problem In this pic you can see that pinfinder is turn it on. Another one! Thank you very mucho for your help! |
11-27-2009, 18:29 | #2 (permalink) |
Freak Poster Join Date: Jun 2005 Location: CNC--GSM--MAROC Age: 47
Member: 156361 Status: Offline Sonork: 618717259 Thanks Meter: 66 | Peace friend you have a problem in the cable link Pinfinder change cable good |
The Following User Says Thank You to nicostar For This Useful Post: |
11-27-2009, 19:11 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! yes please tell us if this cable is from infinity box package? if yes- check with multimeter (resistance measuring) if all 8 wires has good connection between each other ends |
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post: |
11-27-2009, 19:29 | #5 (permalink) | |
Member: 587123 Status: Offline Thanks Meter: 7 | Quote:
Here you can see all the cable. | |
11-27-2009, 22:29 | #8 (permalink) |
Banned Join Date: Nov 2009 Location: @ work Age: 16
Member: 1169642 Status: Offline Sonork: 1587581 Thanks Meter: 234 | brother i had a problem like this but when i bought another cable my problem solved 100% am sure that is cable .change cable and tell me |
The Following User Says Thank You to GSM SOLUTION. For This Useful Post: |
11-29-2009, 07:29 | #10 (permalink) |
Member: 587123 Status: Offline Thanks Meter: 7 | Unfortunately it is not a cable problem i have a friend who has infinity box + pinfinder and my cable conect his pinfinder very well, so i found the problem is my infinity box but i do not know where is the problem maybe you can give some solution?? |
11-30-2009, 18:24 | #11 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i think it is better to exchange this box under warranty conditions. but if you already opened warranty seals it is worth to inspect soldering inside box. few days back i repaired one box. there was shortcutted two processor legs. |
PinFinder Box can't be detected | ottyone | Infinity-Box | 4 | 12-04-2008 22:01 |
G600i Can't be done :( | Fre3 Crack3r | TSMbox+ | 6 | 12-21-2006 21:14 |
Siemens a60 Power ON can't be detected! | robertogsm | E-Gold Based Phones | 1 | 11-23-2005 20:39 |
A52 can't be detected ! | equinoks | Siemens Hardware Repair Area | 5 | 05-11-2004 10:07 |
