08-21-2017, 10:18 | #2 (permalink) |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | Hello, If phone is not supported with the latest build of Infinity CM2, then first post logs with complete phone info.... Thank you... |
The Following User Says Thank You to chandanps18 For This Useful Post: |
08-22-2017, 14:26 | #4 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Turkey
Member: 1169259 Status: Offline Sonork: 100.1648194 Thanks Meter: 149 | Operation : Identify [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 0279AFA9 ID_BLOCK_I : 009600E1 ID_BLOCK_E : 00040000 ID_BLOCK_L : 659376AFA4A76E620ABC7165C09ACE5A ID_BLOCK_L : 2178DDCA1D56FEB7CDC75500CE4E44A3 Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
