05-10-2008, 03:48 | #1 (permalink) |
No Life Poster Join Date: Jan 2008
Member: 683463 Status: Offline Thanks Meter: 188 | please help infinity team and there is no comport but i can go thru support and download files and updates help me infinity team |
05-10-2008, 08:33 | #4 (permalink) | |
But if you tried to connect Rx/Tx/Gnd box wires to any PCB you may damage your box and you must replace FT232 chip (or use another unibox or cables). Search in this forum by word "FT232" helps you for sure. | |
05-10-2008, 08:59 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Glad to see screenshot from last unlock process. Not so many people make screenshots from each unlock process results... I think you have a reason to open box and check it's hardware (f.e. FT232 chip). Don't forget to talk with your reseller before you open box. |
05-10-2008, 09:07 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Yes, this means that Infinity-Box smart-card is Ok but only usb-com port converter (cable part of box) not works well. So you can use Infinity-Box software without any problems with any other cables. |
05-15-2008, 02:58 | #12 (permalink) |
Member: 683463 Status: Offline Thanks Meter: 188 | just want to know infinity team my box is A OK now, my reseller replace the board and here i unlock again konka c926 COM6 [VCP0] selected Device: Konka C926 Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: unlock unlock method: standard Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... . detection phase #2... ................................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom]... file saved: C:\Program Files\InfinityBox\MModule\backup_eeprom_20080515-090818.3FE.bin flash: 01227E22022201:18E59F00000000 Backup required data Done Patch required data... detection procedure, wait... detection procedure completed Patch required data Done Special operation... Special operation Done Write... flash: 01227E22022201:18E59F00000000 Write: eeprom Write Done Finalization... Finalization Done Finished, time used: 173 sec Remove/Install battery now ! thanks again infinity team more power |
bluetooth cotel d5 please help infinity team | amit_varietymob | Infinity-Box | 10 | 07-28-2009 22:33 |
please help infinity team | elmehdi59 | Infinity-Box | 5 | 05-19-2007 14:52 |
new phone cl71 , cf61 dead after flash please help infinity team ??? | gadzetxp | Infinity-Box | 12 | 03-17-2007 11:56 |
please help infinity team for change lang in c261 | rirou | Infinity-Box | 6 | 02-05-2007 19:09 |
