03-06-2008, 08:06 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Apr 2005 Location: Iclouds
Member: 142219 Status: Offline Sonork: 100.107814, Thanks Meter: 368 | please suggest this model cpu is mt 6226ba flash is samsung k5l2731caad770 br mobilecraker |
03-06-2008, 08:58 | #2 (permalink) |
No Life Poster Join Date: Jan 2007 Location: udaipur, I N D I A Age: 37
Member: 422762 Status: Offline Sonork: 100.1593904 Thanks Meter: 973 | connect ur phone with infinity box then read general information of phone & version of flash file..then go to support area & search the flash file with same name... |
03-07-2008, 09:17 | #3 (permalink) |
Member: 142219 Status: Offline Sonork: 100.107814, Thanks Meter: 368 | i know this but here is the log after reading information COM5 selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 chip: 0031:9D1C:0A50 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... slowest Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb Warning: probably flash chip empty, erased, incorrectly flashed or damaged. What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_***x_***x.bin detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: EC257E25082501:FFFFFF00000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF reading [flash]... br mobilecraker |
03-07-2008, 14:04 | #4 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: infinity-box
Member: 720034 Status: Offline Thanks Meter: 213 | Quote:
Pls, see marked text in log file, it looks like flash chip completely erased or damaged. You need to try to flash with different flash files and see results. | |
z550i please add this model for tp unlock... | Brod Aries | DreamBox | 1 | 07-31-2008 20:27 |
Please ADD this Models | Hechizer0 | UST Pro II | 5 | 03-15-2008 11:02 |
please add this model | mj_0990 | Infinity-Box | 3 | 10-10-2007 19:48 |
Please Add this model | jawal | UST Pro II | 5 | 03-06-2007 15:42 |
Raskal, please, Is this model possible????? | eskerra | JAFWM | 3 | 10-23-2006 06:41 |
