Old 09-05-2009, 07:21   #1 (permalink)
mohammed imran's Avatar
Member: 533912
Thanks Meter: 115
infinity pin finder
infinity box pinfinder oroblem when i connect to pinfinder................its come error message like this................what problem plz help
searching adapter at COM4...
too many retries
can't find adapter
searching adapter at COM1...
too many retries
can't find adapter
too many retries
can't find adapter
too many retries
done
Old 09-05-2009, 11:20   #2 (permalink)
meisam's Avatar
Member: 115172
Thanks Meter: 212
First check in your device manager to see if it's detected or not,run dongle manager and read info to check if your pinfinder is already activated and updated for you infinity SN,better to remove all other smart-card based tools to avoid card malfunctioning ...
test and report here.
Old 09-05-2009, 11:34   #3 (permalink)
Member: 231639
Thanks Meter: 16
im having a hard time using this infinity gadget pin finder... manual is more faster than using pinfinder....
Old 09-05-2009, 11:49   #4 (permalink)
Member: 533912
Thanks Meter: 115
its activated....................perfect,,
Dongle serial No (S/N): xxxxxxxx Firmware version: 0112.02
Smart-card status: activated
"UK edition" status: Off
Last launched application: 001F v.0282
Additional activated modules:
- 04: Pin-Finder Adapter
Support area: http://www.infinity-box.com
- Username: xxxxxxx- Password: xxxxxxx
Dongle parameters checksum: 68AE18
Old 09-05-2009, 15:27   #5 (permalink)
meisam's Avatar
Member: 115172
Thanks Meter: 212
If you need pinfinder for chinese phones it's better to use spiderman coz it's quite exceptional but for other platforms infinitry pinfinder rocks ...
Old 09-05-2009, 16:33   #6 (permalink)
Member: 130995
Thanks Meter: 35,227
too many retries
can't find adapter
too many retries
can't find adapter
too many retries
can't find adapter
too many retries
done
Hello,
Did you checked voltage at your unibox pin-1 ? What is volatge value ?
What was happened that PinFinder stop to work ?
Old 09-05-2009, 18:01   #7 (permalink)
Member: 533912
Thanks Meter: 115
how to check voltage.........infinity box or pinfinder.............how to solve this problem plz help infinity team before this box working perfect.................its 4 switch socket 1. 0n..off 2.comport 3.f-bus rx-tx 4.m-bus rts ,cts...........which com to check voltage..........
Old 09-05-2009, 19:15   #8 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
RJ45 connector.
pin 1 and 8
check voltage between of them
use voltmeter for this
Old 09-06-2009, 01:34   #9 (permalink)
Member: 533912
Thanks Meter: 115
value is 4.99 how to solve this problem.............
Old 09-06-2009, 21:31   #10 (permalink)
Member: 148515
hello!
was it working before?
Old 09-07-2009, 08:53   #11 (permalink)
Member: 533912
Thanks Meter: 115
before its working perfect normal mode...............yesteyday its has detect pinfinder and worked and i repair 2 mobile... today i check now its some problem whats procedure to repair this problem,,,,,,,,,,,,plz infinity help and solve my problem...........
Old 09-07-2009, 21:11   #12 (permalink)
Member: 148515
hello!
i cant say remotely what could be a reason for such behavior.
if you sure that you doing all correctly, same way as before-
then only way is exchange it under warranty conditions.
contact your reseller for this
can spiderman used instead of infinity pin finder for infinity box sajin6660 Infinity-Box 8 03-14-2010 09:18
infinity pin finder can't detect spredtrum cpu pin out perfectly md.giousuddinso Infinity-Box 6 10-05-2009 19:08
can find bleu 245x pin out using infinity pin finder. sinikrishna Infinity-Box 1 01-08-2009 12:59
help me for infinity pin finder not actvataed subhdra Infinity-Box 2 04-19-2008 09:52
Infinity Pin Finder Want Update sunnyarora Infinity-Box 1 03-21-2008 10:33
Page generated in 0.26410 seconds with 9 queries
