09-26-2019, 09:41 | #1 (permalink) |
Registered User Join Date: Oct 2011 Location: noshki balochistan pak
Member: 1669709 Status: Offline Sonork: 1654655 Thanks Meter: 163 | plz help me Card with specified AID is not found === DongleManager [Infinity] v1.72 [9/26/2019 12:45:00] === Searching... Dongle can't be found: Card with specified AID is not found |
09-26-2019, 17:39 | #2 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
- Connect dongle/box to PC - Run CardID software - https://www.infinity-box.com/support/?r=7 - Select Card-Reader - Click to "Read" button DO NOT send screenshot/video but copy/paste text from software window ! | |
09-27-2019, 08:14 | #3 (permalink) | |
Member: 1669709 Status: Offline Sonork: 1654655 Thanks Meter: 163 | Quote:
Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 | |
09-27-2019, 09:25 | #4 (permalink) | |
09-28-2019, 06:31 | #5 (permalink) | |
ATR: 3B7D95000080318065B0831148C883009000 Card Manager: A000000018434D00 SerialNumber: 010 ROM: Integrated Circuit Fabricator: 4250 Integrated Circuit Type: 3272 OS: Identifier: 1291 Release Date: 6181 Release Level: 0700 EEPROM: Fabrication Date: 1157 Serial Number: 0103 Batch Identifier: 03EF Module Fabricator: 1292 Module Packaging Date: 1297 IC Card Manufacturer: 2003 IC Em******* Date: 1297 Pre Personalizer: 2004 Pre Personalization Date: 1297 Pre Personalization Equipment Identifier: 00002222 Personalizer: 0000 Personalization Date: 0000 Personalization Equipment Identifier: 00000000 m_iopCard.Serial: 01038D6F03EF1292 GP Version: 2.1.1 SCP Version: 1, Option: 5 | |
09-28-2019, 14:32 | #6 (permalink) | |
09-28-2019, 20:58 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - https://www.infinity-box.com/support/?r=6 OR Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) The next steps are: - run DongleManager - update Dongle firmware IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! |
02-08-2022, 10:11 | #10 (permalink) |
Freak Poster Join Date: Sep 2012 Location: Malawi, Africa
Member: 1814195 Status: Offline Thanks Meter: 17 | Infinity-Box CardID v1.11 Error when connecting Card in: Alcor Micro USB Smart Card Reader 0 SmartCard API error #2148532326 The smart card is not responding to a reset. Iam having this issue on my cm2 v2 (Mt2,Spd2) |
02-08-2022, 11:53 | #11 (permalink) | |
Try to connect Dongle to another PC Try to insert Smart-Card into another Card-Reader or Box If problem still exist: - Remove Smart-Card from Card-Reader - Clean Smart-Card contacts - Try to use hot air gun and heat Smart-Card - Insert Smart-Card back to Card-reader What is the result? | |
