11-24-2016, 10:23 | #1 (permalink) |
No Life Poster Join Date: Feb 2011 Location: ( United States Of Islam ) Age: 35
Member: 1519396 Status: Offline Sonork: 100.1612702 Thanks Meter: 1,951 | Plz help qlm NOT DEDUCTED ANY QUALCOMM PHONE FOR ANY ORATION READ INFO READ PATTREN OR MOR DONGLE FIRMWARE ABOUT DRIVER |
11-24-2016, 10:29 | #2 (permalink) |
Registered User Join Date: May 2008 Location: ...::IsLam::... Age: 39
Member: 767472 Status: Offline Sonork: 100.1609877 Thanks Meter: 599 | i have same isshu did not conect any Qualcom niaz muhammad try it tomorow u are already update 1 time no more chance |
11-24-2016, 12:03 | #5 (permalink) |
No Life Poster Join Date: Mar 2012 Location: India
Member: 1728736 Status: Offline Sonork: 100.1615042 Thanks Meter: 1,098 | Go device manager >port right click Qualcomm HS-USB QDLoader 9008 >properties then install driver> update driver> advance> tick do't search i will......... then click " have disk" then choose infinitybox>cm2QLM>Driver> MANUAL_INST_XP and then select "EmergencyDownload.inf" you are done then connect again with CM2QLM Good Luck |
The Following User Says Thank You to .:Sanjh Phoenix:. For This Useful Post: |
11-24-2016, 12:23 | #7 (permalink) |
Member: 1728736 Status: Offline Sonork: 100.1615042 Thanks Meter: 1,098 | try this and post result http://forum.gsmhosting.com/vbb/f296.../#post12179927 |
11-24-2016, 14:19 | #10 (permalink) |
No Life Poster Join Date: Apr 2015 Location: FLORENCE ITALY
Member: 2375239 Status: Offline Sonork: 100.1662985 Thanks Meter: 962 | here is the complete solution but always post complete log u are using window 10 not sure 32bit or 64 bit watch video twice problem shud be solve thanks if u like wich model u are trying to read coz some of mobiles read method is diffrent some of huawei phone same like htc method means put mobile in download mood or bootloader mood etc i see your vedio you just try same like spd mobile method https://www.youtube.com/watch?v=KzNTxRVF0pI |
11-24-2016, 14:33 | #11 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | 1 install Emergency Mode Drivers Download From Infinity Support Named InfinityBox_update_CM2QLM_Drivers_v1.00.7z 2 after download and install open path/directory C:\InfinityBox\CM2QLM\Drivers 3 install EmergencyDownloadDriver.exe 4 open cm2 qualcomm exe and do select and run which operation you want to do 5 power off mobile pres volume up and down @ same time and insert usb cable Hope It's Clear |
