Old 06-22-2019, 01:18   #1 (permalink)
nessyb's Avatar
Member: 1866877
Sonork: 100.1681933
Thanks Meter: 707
Thumbs up infinix x622 icon fix and baseband fix done solution
STEPS
1)sec backup (from working phone with good baseband)
2)OPEN MEMTOOL on cm2qlm then mark all partions and erase
be patient process takes time 5 min or so
3)use hqxa v1.19 to write firmware https://mega.nz/#!OXwAgIYB!L2o86ImBI...mSKRBQlEo3brcY(use google they are a lot of guides and vids on how to flash with emmc factory tool)
firmware credits HOVATEK
4)after flash restore SEC backup using cm2qlm
this fix baseband and network
ICONS ARE BACK AND FULL NETWORK
LOGS
Operation : EDL Security Operation [ v1.16 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 430 [MSM8937]
ID_BLOCK_S : D75A608E
ID_BLOCK_L : 1BED877FDE44717C2B00F0DD1A61F1D9
ID_BLOCK_L : 314CF25D5EC169FA1FDEB3687AB5A3A8
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ]
ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200
Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : GD6BMB
Boot Ok!
Backup Security Partitions
Backup : FSG
Backup : MODEMST1
Backup : MODEMST2
Backup saved to : Backup\MSM8937_[0004F0E1]_D75A608E_SEC\
Done!
Elapsed: 00:00:37
MEMORY TOLL ERASE LOG
Operation : Memory Tool Init [ v1.16 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Set default path : C:\InfinityBox\CM2QLM\phdata\
Ready!
Operation : Erase Memory [ v1.16 ]
Erase selected partitions [51]
[0] Erase partition : GPT
Erase partition Ok!
[1] Erase partition : MODEM
Erase partition Ok!
[2] Erase partition : FSC
Erase partition Ok!
[3] Erase partition : SSD
Erase partition Ok!
[4] Erase partition : SBL1
Erase partition Ok!
[5] Erase partition : SBL1BAK
Erase partition Ok!
[6] Erase partition : RPM
Erase partition Ok!
[7] Erase partition : RPMBAK
Erase partition Ok!
[8] Erase partition : TZ
Erase partition Ok!
[9] Erase partition : TZBAK
Erase partition Ok!
[10] Erase partition : DEVCFG
Erase partition Ok!
[11] Erase partition : DEVCFGBAK
Erase partition Ok!
[12] Erase partition : DSP
Erase partition Ok!
[13] Erase partition : MODEMST1
Erase partition Ok!
[14] Erase partition : MODEMST2
Erase partition Ok!
[15] Erase partition : DDR
Erase partition Ok!
[16] Erase partition : FSGALL
Erase partition Ok!
[17] Erase partition : FSG
Erase partition Ok!
[18] Erase partition : SEC
Erase partition Ok!
[19] Erase partition : ABOOT
Erase partition Ok!
[20] Erase partition : ABOOTBAK
Erase partition Ok!
[21] Erase partition : BOOT
Erase partition Ok!
[22] Erase partition : RECOVERY
Erase partition Ok!
[23] Erase partition : DEVINFO
Erase partition Ok!
[24] Erase partition : PERSIST
Erase partition Ok!
[25] Erase partition : MISC
Erase partition Ok!
[26] Erase partition : KEYSTORE
Erase partition Ok!
[27] Erase partition : CONFIG
Erase partition Ok!
[28] Erase partition : LIMITS
Erase partition Ok!
[29] Erase partition : MOTA
Erase partition Ok!
[30] Erase partition : DIP
Erase partition Ok!
[31] Erase partition : MDTP
Erase partition Ok!
[32] Erase partition : SYSCFG
Erase partition Ok!
[33] Erase partition : MCFG
Erase partition Ok!
[34] Erase partition : CMNLIB
Erase partition Ok!
[35] Erase partition : CMNLIBBAK
Erase partition Ok!
[36] Erase partition : CMNLIB64
Erase partition Ok!
[37] Erase partition : CMNLIB64BAK
Erase partition Ok!
[38] Erase partition : KEYMASTER
Erase partition Ok!
[39] Erase partition : KEYMASTERBAK
Erase partition Ok!
[40] Erase partition : APDP
Erase partition Ok!
[41] Erase partition : MSADP
Erase partition Ok!
[42] Erase partition : DPO
Erase partition Ok!
[43] Erase partition : OEM
Erase partition Ok!
[44] Erase partition : CACHE
Erase partition Ok!
[45] Erase partition : SPLASH
Erase partition Ok!
[46] Erase partition : LOGDUMP
Erase partition Ok!
[47] Erase partition : VENDOR
Erase partition Ok!
[48] Erase partition : SYSTEM
Erase partition Ok!
[49] Erase partition : USERDATA
Erase partition Ok!
[50] Erase partition : GPTBAK
Erase partition Ok!
Operation finished!
FOR THOSE WHO DONT HAVE WORKING PHONES FOR SEC BACKUP USE
THESE FILES....ALSO HELPS RESTORE BASEBAND UNKOWN WITHOUT DOWNLOAD FULL FIRMWARE
https://mega.nz/#!uVFy0IoQ!axIwwKLO6...FHSVBJKIcWW3s0
PRESS THANKS IF HELPS
The Following 4 Users Say Thank You to nessyb For This Useful Post:
Old 06-22-2019, 01:30   #2 (permalink)
nessyb's Avatar
Member: 1866877
Sonork: 100.1681933
Thanks Meter: 707
password
cm2qlmx622infini
Old 06-22-2019, 01:44   #3 (permalink)
nessyb's Avatar
Member: 1866877
Sonork: 100.1681933
Thanks Meter: 707
password
cm2qlmx622infini
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Restore Security Partitions
Write : FSG
Write from : C:\InfinityBox\CM2QLM\Backup\MSM8937_[0004F0E1]_D75A608E_SEC\fsg.bin
Write : MODEMST1
Write from : C:\InfinityBox\CM2QLM\Backup\MSM8937_[0004F0E1]_D75A608E_SEC\modemst1.bin
Write : MODEMST2
Write from : C:\InfinityBox\CM2QLM\Backup\MSM8937_[0004F0E1]_D75A608E_SEC\modemst2.bin
Done!
Elapsed: 00:00:56
Reconnect Power/Cable!
PROOF
ICONS
do you have to have car insurance to drive
The Following User Says Thank You to nessyb For This Useful Post:
Old 06-22-2019, 20:48   #4 (permalink)
Member: 1677653
Thanks Meter: 2,769
Only the flash tool and factory firmware is enough.
I have done many....
The Following User Says Thank You to Yusuf Lawal For This Useful Post:
Old 06-25-2019, 02:26   #5 (permalink)
nessyb's Avatar
Member: 1866877
Sonork: 100.1681933
Thanks Meter: 707
ooh i think you did not get the reason for this post
ITS ABOUT SHARING LITTLE SOLUTIONS TO COMMUNITY
EVERYONE HERE HAVE IN SOME WAY FIND OWN SOLUTIONS SO DONT BRAG ABOUT IT
KINDLY SHARE WITH US,YOUR GSM BROTHERS
The Following 2 Users Say Thank You to nessyb For This Useful Post:
Old 01-26-2020, 14:50   #6 (permalink)
Member: 2918520
download link dead
hi please upload SEC BACKUP again or fix the link is broken and i dont have other working phone to get backup from.
Page generated in 0.18803 seconds with 8 queries
