07-09-2008, 13:18 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Location: HYDERABAD
Member: 126000 Status: Offline Sonork: 100.1593044 Thanks Meter: 111 | post here all infinity problems airtel unlock method#2 COM46 [VCP0] selected Device: LG KG270 Checking data, wait... Action: unlock direct unlock method #2 (Airtel etc.) Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... flash chip supported sw version: ULC2GL CIS Open KG270 KG275 P16 07 V10e ***-XX MAY 30 2007 +0 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: D:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20080709-164235.B1E.bin loading data... data loaded imei: 35558801527161700 reading [eeprom-sec_35558801527161700]... file saved: D:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_35558801527161700_20080709-164240.B1E.bin reading [eeprom-complete_35558801527161700]... file saved: D:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_35558801527161700_20080709-164247.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: eeprom-sec Writing: eeprom-sec probably you need to restore original imei after unlock process Write Done Finished, Remove/Install battery now ! Time used: 33 sec direct unlock method#1 COM46 [VCP0] selected Device: LG KG270 Checking data, wait... Action: unlock direct unlock method #1 Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... flash chip supported sw version: ULC2GL CIS Open KG270 KG275 P16 07 V10e ***-XX MAY 30 2007 +0 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: D:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20080709-164410.B1E.bin loading data... data loaded imei: 35558801527161700 reading [eeprom-sec_35558801527161700]... file saved: D:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_35558801527161700_20080709-164414.B1E.bin reading [eeprom-complete_35558801527161700]... file saved: D:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_35558801527161700_20080709-164421.B1E.bin backup critical area Done Check memory... loading data... data loaded loading data... data loaded loading data... data loaded loading data... data loaded code: 88025275 code: 0000000000000000 error: not locked or unknown eeprom Check memory Failed Finished, Remove/Install battery now ! Time used: 42 sec read unlock codes still insert sim. |
07-09-2008, 15:00 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you ! You have posted perfect log of Infinity-Box operations and everybody can see that Infinity-Box software works perfect ! Thank you very much for so detailed confirmation that Infinity-Box software is good ! Also for your information: if you will have (but I am sure that you will not) any problem with Infinity-Box you must read documentation first ! C:\Program Files\InfinityBox\Documentation Just an example of documentation that you ignored: C:\Program Files\InfinityBox\Documentation\Infinity-Box_How_to_unlock_Samsung_c140_Airtel_India It was your big mistake to ignore documentation, you must read documentation to get more experience. Good luck ! |
07-10-2008, 08:06 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @f164 Please, more information with logs @..:HGSM:.. Thanks for report ! @malkeet Make "unlock" after flashing @BHARGAV C:\Program Files\InfinityBox\Documentation\Infinity-Box_How_to_enter_unlock_code_LG-MG160_MG161_KG270_KG271_KG275_KG276_KG278_KG288_KG 370_KG375.txt Why not read documentation ? Is it was not enough C140 example ? |
07-11-2008, 07:48 | #9 (permalink) |
Member: 126000 Status: Offline Sonork: 100.1593044 Thanks Meter: 111 | not working after flashi mobile shows insertsim.i put another sim into mobile shows same insert sim.after i enter nlock code says emergency calls only bt not unlocking.i saw all documatation. |
07-11-2008, 11:09 | #11 (permalink) |
Member: 126000 Status: Offline Sonork: 100.1593044 Thanks Meter: 111 | Still Insert Sim COM36 [VCP0] selected Device: LG KG270 Checking data, wait... Action: unlock direct unlock method #2 (Airtel etc.) Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... flash chip supported sw version: ULC2GL KG270 P16 AFR V10d ***-XX Jun 13 2007 +0 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: D:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20080711-153555.B1E.bin loading data... data loaded imei: 35558801045775700 reading [eeprom-sec_35558801045775700]... file saved: D:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_35558801045775700_20080711-153600.B1E.bin reading [eeprom-complete_35558801045775700]... file saved: D:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_35558801045775700_20080711-153608.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: eeprom-sec Writing: eeprom-sec probably you need to restore original imei after unlock process Write Done Finished, Remove/Install battery now ! Time used: 51 sec Phone must be SWITCHED ON ! Connecting, wait... Connection Ok Repair imei... software version: KG270P16-AFR-V10d-***-XX-JUN 13 2007+0 original imei: 35558801045775700 new imei: 35558801045775 imei verification Ok Done Finished |
07-11-2008, 11:52 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @BHARGAV if your phone show on LCD \"INSERT SIM\" this means that phone hardware is damaged or your sim card is damaged ! Phone is NOT locked but phone is DAMAGED and you must repair phone hardware ! I hope you will be more correct with your words and false reports about Infinity-Box faults, you must get some experience first to say about problems with Infinity-Box. It\'s not Infinity-Box fault, it\'s problem with your phone hardware and your small phone repair experience. |
07-11-2008, 15:20 | #15 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @Ibn\'arabi @BHARGAV If your phone can not accept any card and write \"INSERT SIM\" I dont think it\'s software problem |
Post here all the problems for New Sonyericsson model from K800 and newer | roro_manool | Sony Ericsson Hardware Repair | 474 | 12-06-2014 16:09 |
Post here all software problem | amar22ado | WD2 & APE (Symbian Phones) | 6 | 12-03-2009 03:27 |
Post Here All Ur Problems Appears On Ufsx | CONTACT-GSM | Nokia Hardware & Hardware Repair | 45 | 08-13-2006 04:45 |
Post Here All Ur Problems Appears On Ufsx | CONTACT-GSM | Nokia Hardware & Hardware Repair | 0 | 02-06-2006 14:27 |
