12-14-2008, 13:42 | #1 (permalink) |
Freak Poster Join Date: Oct 2005 Location: Tunisia
Member: 188803 Status: Offline Thanks Meter: 4 | L342 blinking revived by LgA v1.25 flash AlchemyData downloaded from support C3320P40-07-V112-000-00_SEP_08_2006AlchemyData.B1P CodeData downloaded from support too C3320P40-07-V112-000-00_SEP_08_2006CodeData_w_calibration.B1M tool used LGA v1.25 Here is the log COM4 [VCP0] selected Device: LG C3320 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881500010001:89881500000000 flash: 89881500010001:89881500000000 flash: Intel 128MBit-B Strata B 16Mb id: 00005272 Boot Done Set baud... 921600 Set baud Done Check flash... current eeprom imei: 356186000673936 file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom_35618600067393 6_LG C3320_20081214-034934.B1E.bin . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) flash: 89881500010001:89881500000000 flash: 89881500010001:89881500000000 Write: Alchemy data flash: 89881500000000:89881500000000 flash: 89881500000000:89881500000000 Write Done Finished, time used: 1021 sec Remove/Install battery now ! Then I chek IMEI is ok Network is ok Sound is ok Phone is ok for those who have the same problem just do as i do and it will be ok |
The Following User Says Thank You to dabdoub2005 For This Useful Post: |
12-14-2008, 13:52 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
why! flashing support of kg290 is blocked in Lga v1.38 | ashrafi580 | Infinity-Box | 4 | 06-14-2010 09:02 |
LGA 1.25 Module Needed | maplegsm | Infinity-Box | 2 | 01-25-2009 12:11 |
w810 red blink revive by setool | mcjude | Sony Ericsson | 0 | 11-12-2008 10:46 |
did not see LGA V1.25 in support section-help | zonetrichur | Infinity-Box | 1 | 01-27-2008 07:03 |
