06-26-2016, 18:48 | #1 (permalink) |
Freak Poster Join Date: Mar 2014 Location: Earth
Member: 2156783 Status: Offline Thanks Meter: 95 | Problem on Activation CM2 on Dongle Manger ---------- Process started: 22/06/2016 16:42:45 ---------- DongleManager [Infinity-Box] v1.63 [22/06/2016 16:42:45] PC HWID: DFC43B3DDA7FB7EDBD13781E8EEA8148 Card-Reader: Generic CCID Smart Card Reader 0 HWID: 0007928A18201292 Type: [BEST] S/N: A2B7928A Version: 0122.02 Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Error securing session: Can not select CardManager: SCardTransmit error SmartCard API error #31 0x0000001F Disconnected |
09-01-2017, 02:18 | #3 (permalink) | |
Freak Poster Join Date: Feb 2008
Member: 705926 Status: Offline Thanks Meter: 5 | Quote:
Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 00005059176D4082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 6CA15059 Firmware version: 0118.02 === Process started: 8/31/2015 17:51:16 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0005] Authentication failed! Dongle is not Registered yet ? You should "Register" before you start update ! Click to "Yes" to start Registration process. If you are already registered click to "No" Can not connect to server ! Disable Antivirus/Firewall and try again ! Can not connect to server ! Disable Antivirus/Firewall and try again ! Can not connect to server ! Disable Antivirus/Firewall and try again ! Can not connect to server ! Disable Antivirus/Firewall and try again ! Can not connect to server ! Disable Antivirus/Firewall and try again ! Can not connect to server ! Disable Antivirus/Firewall and try again ! Can not connect to server ! Disable Antivirus/Firewall and try again ! Can not connect to server ! Disable Antivirus/Firewall and try again ! | |
09-01-2017, 08:06 | #4 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Quote:
ALSO U NEED TO RENEW YOUR SUPPORT PERIOD TO USE LATEST CM2 MODULES. WBR sahil2000ind | |
09-02-2017, 00:06 | #5 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
help [at] infinity-box.com | |
03-10-2020, 11:27 | #6 (permalink) |
Crazy Poster Join Date: Apr 2015 Location: Nigeria,MAIDUGURI.
Member: 2374960 Status: Offline Sonork: [email protected] Thanks Meter: 5 | === DongleManager [Infinity] v1.72 [1/16/2020 2:51:47] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: GsmEasy S-Reader 0 HWID: 00007CCA200A4082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 1F657CCA Firmware version: 0118.02 === Process started: 1/16/2020 2:51:49 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0005] Authentication failed! Dongle is not Registered yet ? You should "Register" before you start update ! Click to "Yes" to start Registration process. If you are already registered click to "No" Can not connect to server ! Disable Antivirus/Firewall and try again ! |
03-10-2020, 13:49 | #7 (permalink) | |
Disable firewall and antivirus and try to register it once again. If problem still exist send a problem details to support via mail: help [at] infinity-box.com | |
