Old 02-12-2008, 20:30   #1 (permalink)
Member: 67188
problem with new version v 2.27 chines miracle
with new version v 2.27 chines miracle write :
COM4 [VCP0] selected
Action: reset settings
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200
Initializing[6225:8A03:8A00]...
CPU: MT6225
chip: 0001:8003:0000
Connecting, wait...
Release Power button now !
Phone detected, wait...
warning: can't read software version, probably unknown firmware
detecting structure #2...
0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18
warning: wrong packet cs 19 20 21 22 23 24 25
error: detection failed (26 tries), read flash and send to support
connection lost
error: operation failed !
Finished, time used: 11 sec
Remove/Install battery now !
i have nokia n82i
Old 02-12-2008, 22:31   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
please make complete format instead of safe
better make backup before this for emergency case
Old 02-13-2008, 14:11   #3 (permalink)
Member: 67188
complete format
in complete format write:
Device: Autodetect 6205-6227 NOR
eeprom backup enabled, it may takes several minutes !
Action: reset
Boot...
baud autodetection active
19200
Connecting, wait...
CPU: MT6225
boot step size: 0400
Boot Done
Initialize...
flash: EC257E25082501:18E59F00000000
error: no any expected answer: wrong answer after chip cfi request
flash: Samsung D 16Mb
detecting chip #01 in region #00...
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Identification...
device parameters autodetection in progress..
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: E558_JQ3F8_E558_GPRS_MT6225_S00.V60_01_1.BIN
ver. sw2: E558_JQ3F8.V60.01.1, 00000000
ffs offset/size: 00E00000/001FF000
detect device identification#2...
warning: optional information not found
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
reading [eeprom[E558_JQ3F8_E558_GPRS_MT6225_S00.V60_01_1.BIN]]...
warning: wrong data size at 0x00E03000, retry...
error: too many retries during read operation
Probably errors exist during flash read operation.
Do you want to repeat read operation ?
operation canceled by user
Old 02-13-2008, 15:29   #4 (permalink)
mansi's Avatar
Member: 8664
Sonork: 100.1573507
Thanks Meter: 56
is it ZTC phone?
Mansi
Old 02-13-2008, 16:16   #5 (permalink)
Member: 404566
Thanks Meter: 30
my friend
please just use 460800 baud rate for this error
Old 02-13-2008, 16:22   #6 (permalink)
Member: 130995
Thanks Meter: 35,227
@yacino77
What type of cable you have used ?
There is a big chance that it's cable problem.
Old 02-13-2008, 16:44   #7 (permalink)
Member: 67188
please solution for this problem
Old 02-13-2008, 16:50   #8 (permalink)
Member: 67188
i have original cable for infinity box
Old 02-13-2008, 23:38   #9 (permalink)
Member: 130995
Please, give me an answers to all my questions:
1. What was original phone condition ?
2. What is battery voltage ?
3. Did you had a chance to open phone and check it's hardware ?
4. Did you tried to repeat the same operation ?
5. if yes, what is the results ?
6. if the same error exist: is the error on the same address or on different addresses during reading ?
7. did you tried to make "format" with disabled "backup" option in "settings" page ?
Old 02-15-2008, 18:12   #10 (permalink)
Member: 67188
i test all solution
not work
Old 02-15-2008, 22:21   #11 (permalink)
Member: 148515
Old 02-17-2008, 11:12   #12 (permalink)
fateh76dz's Avatar
Member: 51746
Thanks Meter: 47
nade N82i PinOut
hlep
Old 02-17-2008, 13:28   #13 (permalink)
Member: 130995
Dear Friend,
Currently many "Chinese" models with the same name but absolutely different hardware exist on market.
Exmple: exist at least 20 phones with name "Chinese Nokia-N95" but all models has difference in hardware,
different bottom connectors, different pinouts and and has different firmware,
so we recommend you to include the next information in your request regarding pinout:
1. detailed description of model: brand name, model name, complete text from phone back label, any other marks that you can find on phone cover
2. phone CPU chip name
3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB)
4. attach phone photo
5. attach phone bottom connector photo
6. include information about Gnd and Charge pins on phone bottom connector
After you have this information prepared, you can find pinout by yourself more easy than before,
just check the next detailed description how to get pinout for your model:
1. use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297
2. if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\
3. if not helps, please read: http:///vbb/showpo...36&postcount=7
4. if not helps, please read: http:///vbb/showthread.php?t=433447
Ustpro2 - problem with new versions ! raven25 UST Pro II 4 08-24-2006 00:06
problem with new version nsdongle fonesunlock NSPRO 0 12-14-2005 11:17
problem with new version 1.22 ADD-GSM Twisterflasher 6 07-05-2004 13:48
Page generated in 0.20397 seconds with 9 queries
