== problem unlock ZTE coral 200 == problem unlock coral 200 can`t enter code with or without sim... i have 10pcs. here any suggestion for this?? COM5 [VCP0] selected Device: Coral-200 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 00EC:22A0 Connecting Done Check hardware... flash chip supported Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: D:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20080328-192828.B1E.bin loading data... wrong database file: D:\Program Files\InfinityBox\Pana01\z225_eep65535.cfg error: can't load database v.11 reading [eeprom-sec]... file saved: D:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_20080328-192836.B1E.bin reading [eeprom-complete]... file saved: D:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_20080328-192842.B1E.bin reading [eeprom-dyn]... file saved: D:\Program Files\InfinityBox\Pana01\backup_eeprom-dyn_20080328-192847.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 151 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 TIA... |
How to unlock Coral-200 1. Make eeprom and flash backup for emergency case ! 2. Make "unlock" operation 3. Enter code (if possible) 4. If it's not possible to enter code flash phone with the next files: ZTE-225_Main_VDF-P108A2B06-Bg-BG02_g3dBV2.0_May-31-2007 ZTE-225_LP_VDF-P108A2B06-Bg-BG02_g3dBV2.0_May-31-2007_Bg 5. Make "unlock" operation again |
thank`s for the reply...i`ll try this solution and post result after... |
more pcs success unlocked!!! thank`s to infinity team again...tested solution posted above |
brother wich module to use for unlock coral 200 |
Hello Infinity Supporter! I wait the update for HAIER HG-M101. MCU Name: NXP AMR 6357EL1/3C5/M3 SG8881.1 SG7600.1 ZSG07326 FLASH CHIP: 34HF3282 70-4E-L1PE PINOUT: MINI USB 5 PIN BUT RX-TX REVESRSE OF HUAWEI T128 & T201 Best regards! |
@sweetboy Pana01 module @josh_aina 1. use cable for ZTE-7610 (pinout and picture in in Infinity-Box Shell) 2. try to read flash from HAIER HG-M101 like ZTE-7610 if it will be possible to read flash, please, send flash backup file to [email protected] Let's see results |
But for now HAIER HG M101 not updated!!!!!!!!!!!!!!!!!!!!!!!!!!!! |
