03-29-2008, 07:23 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: Philippines
Member: 306786 Status: Offline Sonork: 100.1596805 Thanks Meter: 516 | == problem unlock ZTE coral 200 == i have 10pcs. here any suggestion for this?? COM5 [VCP0] selected Device: Coral-200 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 00EC:22A0 Connecting Done Check hardware... flash chip supported Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: D:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20080328-192828.B1E.bin loading data... wrong database file: D:\Program Files\InfinityBox\Pana01\z225_eep65535.cfg error: can't load database v.11 reading [eeprom-sec]... file saved: D:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_20080328-192836.B1E.bin reading [eeprom-complete]... file saved: D:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_20080328-192842.B1E.bin reading [eeprom-dyn]... file saved: D:\Program Files\InfinityBox\Pana01\backup_eeprom-dyn_20080328-192847.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 151 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 TIA... |
03-29-2008, 14:57 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | How to unlock Coral-200 1. Make eeprom and flash backup for emergency case ! 2. Make "unlock" operation 3. Enter code (if possible) 4. If it's not possible to enter code flash phone with the next files: ZTE-225_Main_VDF-P108A2B06-Bg-BG02_g3dBV2.0_May-31-2007 ZTE-225_LP_VDF-P108A2B06-Bg-BG02_g3dBV2.0_May-31-2007_Bg 5. Make "unlock" operation again |
06-22-2008, 23:21 | #6 (permalink) |
Freak Poster Join Date: Dec 2005 Location: Madagascar
Member: 207280 Status: Offline Thanks Meter: 15 | Hello Infinity Supporter! I wait the update for HAIER HG-M101. MCU Name: NXP AMR 6357EL1/3C5/M3 SG8881.1 SG7600.1 ZSG07326 FLASH CHIP: 34HF3282 70-4E-L1PE PINOUT: MINI USB 5 PIN BUT RX-TX REVESRSE OF HUAWEI T128 & T201 Best regards! |
06-23-2008, 08:44 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @sweetboy Pana01 module @josh_aina 1. use cable for ZTE-7610 (pinout and picture in in Infinity-Box Shell) 2. try to read flash from HAIER HG-M101 like ZTE-7610 if it will be possible to read flash, please, send flash backup file to [email protected] Let's see results |
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post: |
problem unlocking HTC wiza 200 MDA T MOBILE | sameenshah123 | HTC & PDA WM( With Touchscreen) | 10 | 06-22-2011 08:08 |
Problem unlocking zte x761 | scorpionly | Easy-Unlocker | 8 | 10-21-2009 16:32 |
Problem Unlocking zte FW-46 | Trooperx17 | Vodafone Star | 4 | 07-06-2009 19:09 |
Problem unlocking ZTE X760 | jerrel_s | Infinity-Box | 1 | 05-26-2009 14:44 |
Problem Unlocking ZTE A35 | .::Pieta::. | SAGEM JTAG UNLOCKER | 1 | 04-22-2009 08:28 |
