11-25-2013, 18:32 | #1 (permalink) |
Freak Poster Join Date: Oct 2007 Location: @ Ajmer
Member: 603777 Status: Offline Thanks Meter: 356 | Procedure To Unlock Alcatel C131(Warning) how to all....plz first check your hardware detail....there is 2 PCB which same version and same compile Date..... 1.so if u have 8 MB Flash Chip....your handset will be come blinking Problem.... 2.if u have 16 MB Flash Chip....your handset wil unlock 100% now how u can detect Flash Chip Simple Way 3. just Check Backside of Phone below MEID u have seen printed..... A. C131-2AMSIN1(8 MB FLASH CHIP) B. C131-2BMSIN2(16 MB FLASH CHIP) SO PLZ UNLOCK "C131-2BMSIN2" THIS HARDWARE VERSION ONLY. FOR C131-2AMSIN1(8 MB FLASH CHIP) WILL BE UPDATE SOON.. |
The Following 3 Users Say Thank You to krish491 For This Useful Post: |
11-25-2013, 19:50 | #2 (permalink) |
Product Supporter Join Date: Jun 2010
Member: 1319166 Status: Offline Thanks Meter: 1,476 | Read Before Unlock ALcatel_C131. Hi, First of sorry to loving user for bearing with me the problem of unlock Alcatel-C131. There is two kind of pcb Version Exist with same Compile date but Different Firmware Inside.That's Why few phone getting Unlocked Successfully But few Phone Not getting Unlock Successfully. To difference Between Two firmware there is easy Method .Few Read carefully below procedure before Unlock for Time being Till we update our software. 1)Connect Phone with The patched flasher and click Update. 2)It will Give error No problem .Now Select model Alcatel and read Info . 3)IF Read Information Shows as below Code: --------------------------------------------------------- HARDWARE : V MTS C1 COMPILE : Jun 25 2013 (10:07:15) REALEASE : Apr 29 2011 (05:00:00) SW Version : q1100 SBNAALZ 3390 --------------------------------------------------------- Phonce code : 0000 Finished, time used: 1 sec 5)If information Shows like this Code: --------------------------------------------------------- HARDWARE : V MTS C1 COMPILE : Jun 25 2013 (13:12:50) REALEASE : Apr 29 2011 (05:00:00) SW Version : q1100 SBNAALZ 3390 --------------------------------------------------------- Phonce code : 0000 Finished, time used: 2 sec Second Method to Detect Different Version of phone with same Compile. 1)Remove Battery of phone . 2) just Check Backside of Phone below MEID u will see phone Model . 3) C131-2BMSIN2 Means this version =COMPILE : Jun 25 2013 (10:07:15) Supported for Unlock 4) Code: 4)C131-2AMSIN1 Means this version = COMPILE : Jun 25 2013 (13:12:50) Not supported for unlock. Special Thanks to Krish491 To figure out Difference between two Pcb with just Physical View. The Above method is temporary Update will be done shortly may be in 1-2 days . We are looking to buy this phone with version HARDWARE : V MTS C1 COMPILE : Jun 25 2013 (13:12:50) REALEASE : Apr 29 2011 (05:00:00) SW Version : q1100 SBNAALZ 3390 --------------------------------------------------------- Phonce code : 0000 Finished, time used: 2 sec Please pm me anyone if have this pcb in hand and want to sell it. Regard's Infinity-CDMA |
