11-07-2010, 07:30 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: srilanka Age: 39
Member: 1133072 Status: Offline Thanks Meter: 505 | prolink f1000 after ffs format show no licened to produce this is formating log ==== [11/4/2010 11:34:01 AM] ==== COM4 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001D03:0007 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.80A21CEA.[GOLDDRAGON25_09A_GEMINI_PCB01_GPRS_MT6225_S00.KXDX 03B2_T3ZSP_NVND_AK_PRO_V02.BIN_6418026D].rpl ==================== New firmware found (v.3.25, database date: 20.10.2010): GOLDDRAGON25_09A_GEMINI_PCB01_GPRS_MT6225_S00.KXDX 03B2_T3ZSP_NVND_AK_PRO_V02.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished device-id: 80A21CEA rom info ver: 07 sw version: GOLDDRAGON25_09A_GEMINI_PCB01_GPRS_MT6225_S00.KXDX 03B2_T3ZSP_NVND_AK_PRO_V02.BIN project-id: KXDX03B2_T3ZSP_NVND_AK_PRO_V02, 6D021864 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 2088C4FFFFFFFF:2088C400000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 2088C4FFFFFFFF:2088C400000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\G OLDDRAGON25_09A_GEMINI_PCB01_GPRS_MT6225_S00.KXDX0 3B2_T3ZSP_NVND_AK_PRO_V02__system_log_80A21CEA_641 8026D_20101104-113519.B0X.bin Finished, time used: 1 min 0 sec Remove/Install battery now ! after format flash file http://rapidshare.com/files/42934698..._part_1_of_1_2 |
11-08-2010, 22:24 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! currently "no license to produce" problem has no solution. we are working under this problem. this situation would be easy resolvable, if you would not refuse automatic eeprom backup... but according to your format Log which you posted in other tread- this was not done |
01-15-2011, 07:51 | #10 (permalink) |
Freak Poster Join Date: Sep 2007 Location: India
Member: 583492 Status: Offline Thanks Meter: 125 | 1 format phone in spiderman box 2 change imie in spiderman box 3 on/off phone 4 format phone in infinity and change imie..with original phone imie 5 select repair Security Area in new version infinity |
The Following User Says Thank You to afhaan For This Useful Post: |
02-27-2011, 21:27 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Please, try to use this new software: http://forum.gsmhosting.com/vbb/f425...y-box-1216399/ We are waiting for test report ! |
03-01-2011, 08:52 | #13 (permalink) |
Member: 1133072 Status: Offline Thanks Meter: 505 | sir thank for update.. nice update. i test this good and working. this is my test report. COM4 [VCP0] selected module v3.27 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware GOLDDRAGON25_09A_GEMINI_PCB01_GPRS_MT6225_S00.A19_ SEQ_A_STT3W0_V11__firmware_part_1_of_1_20101218-171130.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:CA03:0001 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFF0026:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFF0026:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFF0026:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFF0026:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\InfinityBox\ChineseMiracle\backup_security\id.6 EC6C063.[GOLDDRAGON25_09A_GEMINI_PCB01_GPRS_MT6225_S00.A19_ SEQ_A_STT3W0_V11.BIN_4CE82AD0].rpl ==================== New firmware found (v.3.27, database date: unknown): GOLDDRAGON25_09A_GEMINI_PCB01_GPRS_MT6225_S00.A19_ SEQ_A_STT3W0_V11.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished device-id: 6EC6C063 rom info ver: 07 sw version: GOLDDRAGON25_09A_GEMINI_PCB01_GPRS_MT6225_S00.A19_ SEQ_A_STT3W0_V11.BIN project-id: A19_SEQ_A_STT3W0_V11, D02AE84C code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... No licensed to produce fix... No licensed to produce done Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... rpl file not found: C:\InfinityBox\ChineseMiracle\id.6EC6C063.[GOLDDRAGON25_09A_GEMINI_PCB01_GPRS_MT6225_S00.A19_ SEQ_A_STT3W0_V11.BIN_4CE82AD0].rpl rpl file not found: C:\InfinityBox\ChineseMiracle\id.6EC6C063._GOLDDRA GON25_09A_GEMINI_PCB01_GPRS_MT6225_S00.A19_SEQ_A_S TT3W0_V11.BIN_4CE82AD0_.rpl startup code area #1 backup loaded startup code area #1 calculation... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent file saved: C:\InfinityBox\ChineseMiracle\backup_security\GOLD DRAGON25_09A_GEMINI_PCB01_GPRS_MT6225_S00.A19_SEQ_ A_STT3W0_V11__system_log_6EC6C063_4CE82AD0_2011030 1-131043.B0X.bin Area: Firmware flash: 2088C4FFFF0026:2088C400000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done file saved: C:\InfinityBox\ChineseMiracle\backup_security\GOLD DRAGON25_09A_GEMINI_PCB01_GPRS_MT6225_S00.A19_SEQ_ A_STT3W0_V11__system_log_6EC6C063_4CE82AD0_2011030 1-131104.B0X.bin Finished, time used: 1 min 1 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to .::Gsm_Srilanka::. For This Useful Post: |
03-02-2011, 06:54 | #14 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @chamisrilanka please, send full flash file to [email protected] Thank you ! Code: ==================== New firmware found (v.3.27, database date: unknown): GOLDDRAGON25_09A_GEMINI_PCB01_GPRS_MT6225_S00.A19_ SEQ_A_STT3W0_V11.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
