03-19-2020, 16:05 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: rainak bazar jalandhar
Member: 1002949 Status: Offline Sonork: 100.1582346 Thanks Meter: 273 | proscan plt7774g rockchip cpu frp problem ----- > Phone/Tablet : 1. Power Off device 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable! Press 'POWER_ON' button for a few second! ----- > IoT/Box : 1. Reset device power 2. PRESS and HOLD 'RESET' KEY! 3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second! Wait for device ... Device Connected! Interface test : Passed Device mode : Protected! [ LOADER PROTECTED ] SoC CPU : 312A Flash CSx : 0x00 Flash Type : ADDE14AB42 [ NAND ] Flash Vend : HYNIX Flash Size : 0x0000000210000000 ( 8.25 GiB ) Flash Info : 4194304/16384/32/40/1 Connect Ok! Remove FRP 0 ... FRP removed! Wiping UserData ... Wipe DATA Ok! Done! Elapsed: 00:00:12 please give solution |
03-19-2020, 22:53 | #6 (permalink) | ||
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Right now solution require more static data to analyze DRAM/FLASH setting in able to make all fast, correct and problem-free work. | ||
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
09-14-2020, 16:17 | #7 (permalink) |
Insane Poster Join Date: Sep 2017 Location: Jhelum
Member: 2762776 Status: Offline Thanks Meter: 22 | Operation : Identify [ v2.01 ] ----- > Phone/Tablet : 1. Power Off device 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable! Press 'POWER_ON' button for a few second! ----- > IoT/Box : 1. Reset device power 2. PRESS and HOLD 'RESET' KEY! 3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second! Wait for device ... Device Connected! Interface test : Passed Device mode : Protected! [ LOADER PROTECTED ] SoC CPU : 312A Flash CSx : 0x00 Flash Type : ADDE14AB42 [ NAND ] Flash Vend : HYNIX Flash Size : 0x0000000210000000 ( 8.25 GiB ) Flash Info : 4194304/16384/32/40/1 Connect Ok! Brand : PROSCAN ProdName : PLT7774G ProdModel : PLT7774G Device : rk3126c AndroidVer: 7.1.2 Manufact. : Harmony SysPatch : NHG47K RKTxCPU : RK3126C RKTxPRJ : NHG47K release-keys_20180626-1549 Done! Elapsed: 00:00:07 Operation : Reset Settings [ v2.01 ] ----- > Phone/Tablet : 1. Power Off device 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable! Press 'POWER_ON' button for a few second! ----- > IoT/Box : 1. Reset device power 2. PRESS and HOLD 'RESET' KEY! 3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second! Wait for device ... Device Connected! Interface test : Passed Device mode : Protected! [ LOADER PROTECTED ] SoC CPU : 312A Flash CSx : 0x00 Flash Type : ADDE14AB42 [ NAND ] Flash Vend : HYNIX Flash Size : 0x0000000210000000 ( 8.25 GiB ) Flash Info : 4194304/16384/32/40/1 Connect Ok! Remove FRP 0 ... FRP removed! Wiping UserData ... Wipe DATA Ok! Done! Elapsed: 00:00:03 Format and Read Info Done but tablet is still locked on FRP Lock |
