10-25-2016, 16:07 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: pakistan Age: 41
Member: 227726 Status: Offline Thanks Meter: 297 | Q M95 dead cm2 after flash format not give flash Phone found! [ 82 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! [FL] : User decide to make whole erase [FL] : FLASH_FULL_FORMAT executing , wait ... [FL] : FLASH_FULL_FORMAT Ok! PMTManager : Load 0x17 records PMTManager : PMT Update Failed!!! Selected firmware doesn't match to current HW or EMPTY battery! Flashing terminated! Elapsed: 00:00:39 Reconnect Power/Cable! Finish at : [10/25/2016 / 6:17:09 AM] Start at : [10/25/2016 / 6:17:26 AM] Operation : Flash [ v1.22 ] ======= Flash Files set for flashing : [ MCU ] : SC77xx Infinity Package 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 82 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x17 records PMTManager : PMT Update Failed!!! Selected firmware doesn't match to current HW or EMPTY battery! Flashing terminated! Elapsed: 00:00:01 Reconnect Power/Cable! Finish at : [10/25/2016 / 6:17:58 AM] Start at : [10/25/2016 / 6:18:16 AM] Operation : Flash [ v1.22 ] |
10-25-2016, 16:11 | #2 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Lahore Age: 38
Member: 1016490 Status: Offline Thanks Meter: 290 | Is your phone M95 or M95 V2 ? If M95 then flash with this file. But before charge your battery. Its important. ROM Qmobile M95 Firmware | [Official] add the 04/27/2016 on Needrom |
10-25-2016, 16:18 | #3 (permalink) | |
Member: 227726 Status: Offline Thanks Meter: 297 | Quote:
Reading extended info ... Model Name : scx35_sp7731geaplus_dt Model Brand : QMobile Model Device: scx35_sp7731gea AndrVersion : 4.4.3 BaseBand CPU: SP7731GEA CompileDate : 7/31/2015 12:00:38 PM Project Ver : KOT49H 14B_test-keys Model Ext : QMobile M95 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:19 and battery is 91 percent charged bro | |
10-25-2016, 16:27 | #4 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, What was phone condition before flash? Did you made firmware backup and Flash IC Test? Br. Infinity Box Support Team. |
10-25-2016, 16:41 | #5 (permalink) | |
and flash ic test screen short is | |
10-26-2016, 12:14 | #10 (permalink) | |
FlashMode Set : Ok! PMTManager : Load 0x17 records PMTManager : PMT Update Failed!!! Selected firmware doesn't match to current HW or EMPTY battery! Flashing terminated! | |
10-26-2016, 14:18 | #11 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | Quote:
I did not receive any phone like that. further read already posted Mr.Jaydi's replies regarding same issue. | |
The Following User Says Thank You to Nasir Mobiles For This Useful Post: |
10-26-2016, 16:43 | #12 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Erase option is used when really needed, not need to use everytime. And before erase it's recommended to make FlashIC test, just to be on safer side. It could be due to bad FlashIC as well. Try with original tool and firmware once and check result. Br. Infinity Box Support Team. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
10-26-2016, 18:39 | #13 (permalink) |
No Life Poster Join Date: Oct 2015 Location: Unknown
Member: 2469611 Status: Offline Thanks Meter: 389 | That is Your Mistake Bro Why You Erased Flash Instead Of Normal Flashing Don't Blame CM2 Any Way Just Look Here May Be It Will Help You==> http://forum.gsmhosting.com/vbb/f296...-done-2144348/ Regards |
The Following User Says Thank You to CYB3R GSM For This Useful Post: |
