[Q|A] : Why HWreport matter first on newer devices? HWreport feature allow you NOT care about correct selection for/per device settings. Preloader , DA in case of brom ( for default , and secboot configuration ) It allow rid off from most common issues : Code: DA : BOOT 2ND DA FAILED! Code: DA : EXT_RAM NOT initialized! After once HW report done, check it result. In some cases may be need UP EMI number in platfrom tab to sucess boot uncommon device configurations. |
2021 Is the year of hope. Thank you so much for this out of the box update. |
Xiaomi Mi Play MT6765 Failed Quote:
Add your user+password to cm2mt2 setting to last DB update and retry |
SAME ISSUE !!! i Updated DB Quote:
I THINK you use old proto in cm2mt2 setting Change it to newest version [2] |
Tried 1 and 2 both failed |
Yes device hang on first logo .. i connect with VOL DOWN |
If result same - seems as HW issue. Agent not starting at all. |
Oppo A12 CPH2083 Oppo A12 CPH2083 Identify / Connect Code: Operation : Identify [ v2.17 ] |
problem is here |
oppo f11 Load IDBase v125162 Ok! Operation : HW Report [ v2.18 ] HWreport : Mode : eMMC 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM73) MODE : BOOTROM PORT : 73 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Sylvia TYPE : MODERN RAPHAEL BROM : MEID : AE99CB37D0C1D4893A76F9371B9FA99F BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : E04FE63DFAB1C78005E24535A2A94C315DE1E99A3CB1753F0B C487BAEA1C9882 BROM : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001] AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! INFO : BROM Level : CERT/AUTH required! Try boot device in PRELOADER mode with select PL/PL_CRYPTO/SWSEC type! Info : LEGACY : HW reporting feature unavailable for current device! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Done! Elapsed: 00:00:13 |
