Old 09-28-2007, 16:09   #1 (permalink)
Registered User
Member: 76882
Thanks Meter: 56
j100i phone is hacked
hi
2 all
j100i after flash phone is hacked. i flashed R1A002,R1C004, R1E004. STILL SAME PROBLEM, AFTER FLASH I DO IME REPAIR, FFS FORMATE, UNLOCK
PHONE IS HACKED
PLZ HELP ME ONY ONE THIS SOLUTION
Old 09-28-2007, 18:30   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
flash phone with version R1A002 with correspondent LP and Flex.
then push change IMEI with "restore" checked.
make unlock. Phone must be ok after this
Old 10-01-2007, 14:33   #3 (permalink)
Registered User
Member: 76882
Thanks Meter: 56
no way I tried all ways still PHONE IS HACKED
INFINTYHELP please tell me if phone is hacked can we repair with infinity?
The Following User Says Thank You to kiran For This Useful Post:
Old 10-01-2007, 14:53   #4 (permalink)
Registered User
Member: 76882
Thanks Meter: 56
sory sir mobile working fine.
infinity is great & support is very very great.
thanks
regards
Old 10-01-2007, 17:11   #5 (permalink)
Member: 148515
hello!
please post here how did you solve your problem.
which flash files you used, what operation did
Old 06-18-2008, 06:37   #6 (permalink)
kmaxmax's Avatar
Member: 553000
Thanks Meter: 2,302
J100i phone is hacked
hello sir i hv used the same version for flash nd eprom as well nd method
given by u but phone still same phone hacked what should i do i m sending
u the following log:
COM3 [VCP0] selected
Action: unlock
Device: Sony-Ericsson J100
Checking data, wait...
Connect...
Press and HOLD Power button...
connection mode: 00
Release Power button !
Connect Done
Boot...
Boot Done
Set Baud...
115200
Set Baud Done
Check Flash-1...
startup condition detected
SW version: R1A002
HW version: _NC2
LP ver: CXC1250396_lp_EU2_R1A002
Flex ver: FFN_NC2_01_FILE 999
imei otp: 359210006027363
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _359210006027363_20080617-223205.80E.bin
imei eeprom: 0173930FA79DD05
error: non-locked or unknown eeprom
Check Flash-2 Fail
Finished, time used: 29 sec
Remove/Install battery now !
what should i do? plz help me infinity team........
Old 06-18-2008, 06:51   #7 (permalink)
Orange_Dominica's Avatar
Member: 88701
Thanks Meter: 381
Hello
IMEI is corrupt... rewrite correct IMEI
Thanks
.....my INFINITY box arrives on FRIDAY!
;smokin
Old 06-19-2008, 19:37   #8 (permalink)
InfinityN's Avatar
Member: 720034
Thanks Meter: 213
Action: unlock
Connect...
connection mode: 00
Connect Done
Boot...
Boot Done
Set Baud...
115200
Set Baud Done
Check Flash-1...
SW version: R1A002
HW version: _NC2
Check Flash-1 Done
Check Flash-2...
reading ...
Check Flash-2 Fail
Good day !
1. make eeprom backup for emergency case
2. write repair eeprom from support area
3. repair imei
Old 07-09-2008, 08:51   #9 (permalink)
Member: 384961
Thanks Meter: 2
just repair the IMEI no with restore option ticked.
I have just done it and phone is working fine.
this is log
COM5 [VCP0] selected
Action: imei repair
new imei: 354155011698754
Connect...
connection mode: 00
Connect Done
Boot...
Boot Done
Set Baud...
115200
Set Baud Done
Check Flash-1...
SW version: R1D009
HW version: _NC2
LP ver: CXC1250384_lp_INDIA_R1D0
imei otp: 354155011698754
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _354155011698754_20080709-131639.80E.bin
imei eeprom: 354155011698754
reading ...
Check Flash-2 Done
Write...
Finalizing...
Write Done
Finished, time used: 62 sec
The Following User Says Thank You to ndavid For This Useful Post:
Old 07-09-2008, 17:39   #10 (permalink)
Member: 130995
Thanks Meter: 35,227
Thank you very much for test report !
Each test report with attached logs is very important for us so we can see how is Infinity-Box
software works and what is possible problems and successfully done work.
Old 08-01-2008, 09:19   #11 (permalink)
b12345's Avatar
Member: 758310
Sonork: 100.1601610
Thanks Meter: 71
Action: unlock
Connect...
connection mode: 00
error: boot failure[04]: general communication fault.
Connect Fail
Finished, time used: 12 sec
sir i m unlocking the phone but recieve this error
what am i do
pls sir help me
Old 08-01-2008, 14:43   #12 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
restore IMEI...........
Old 08-01-2008, 15:02   #13 (permalink)
tuli's Avatar
Member: 511615
Thanks Meter: 35
Originally Posted by b12345 View Post
Action: unlock
Connect...
connection mode: 00
Connect Fail
what am i do
pls sir help me
wrong pinout possible . use correct pinout and all will be ok
Keyboard top
1.........12
9: Gnd
10: phone Rx
11: phone Tx
The Following User Says Thank You to tuli For This Useful Post:
Old 08-27-2008, 06:10   #14 (permalink)
gujjar_brothers's Avatar
Member: 558087
Sonork: 100.1579413
Thanks Meter: 332
hi
sir
i did full flash then change imei ok every thing is ok but phone asked phone is hacked
plz help me thx
Old 08-27-2008, 12:19   #15 (permalink)
Member: 130995
Hello,
Repair imei to it\'s original value (that you can see by imei otp: xxx text in log)
The Following User Says Thank You to InfinitySupport For This Useful Post:
j100i phone is hacked djpaul Infinity-Box 32 12-15-2009 18:44
J100i - phone is hacked? saidgoren Infinity-Box 5 12-12-2008 15:00
j100i phone is hacked alex09494 Infinity-Box 1 08-22-2008 16:36
c117 phone is hacked ..:MumbaiGsm:.. Infinity-Box 2 01-30-2007 10:11
C117 Phone is Hacked.. muksforu Infinity-Box 24 01-03-2007 12:11
Page generated in 0.24551 seconds with 10 queries
