Old 12-06-2016, 18:06   #1 (permalink)
Member: 2501288
Thanks Meter: 328
Exclamation [QLM] G630-U20 Flash Error ProgFinish : Read back verify failed at sector
FLASH G630-u20 error , now on QHSUSB_BULK mode and NOT power on
Card found : S/N : 21098088 , v0134
Infinity-Box Qualcomm Module [QLM] v 1.04
Loading firmware ...
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand : Huawei
Device Manufact.: HUAWEI
Device Model : hwG630-U20
Device CPU : MSM8610
Device IntName : G630-U20
Device Version : 4.3
CU_SWVer : HUAWEI
Device Compile : 09-4-2015 07:40:55
Device ExtInfo : G630-U20
Load Ok!
Operation : Flash [ v1.04 ]
Verify FW package ...
Verification passed!
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12]
ID_BLOCK_S : 0109D1B7
ID_BLOCK_I : 008140E1
ID_BLOCK_L : 5BF3348E763DF04A
ID_BLOCK_L : C060A78CDE6EC186
Pickup loader from firmware package
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1
ExtInfo : 0x0000C000/0000C000/00001000/00001000
Boot Ok!
Files in Chain : 21
Flashing now
Flashing : gpt_main0.bin
Flashing : sbl1.mbn
Flashing : deploy.mbn
Flashing : rpm.mbn
Flashing : tz.mbn
Flashing : emmc_appsboot.mbn
Flashing : NON-HLOS.bin
Flashing : persist.img
Flashing : boot.img
Flashing : recovery.img
Flashing : cust.img
Flashing : cache.img
Flashing : system.img
Flashing : userdata.img
ProgStart : start 3686400, num 8
ProgFinish : Read back verify failed at sector 252441597,num sectors 3686400
Flash Error , No ACK message! Check Battery charge , Cable
Error : Flashing failed!
Check previous message for more info!
Reconnect Power/Cable!
Old 12-06-2016, 20:53   #2 (permalink)
Member: 2501288
Thanks Meter: 328
battery more then 50% and cable good
i flash it with backup flash from anther working g630-u20
Old 12-07-2016, 09:02   #3 (permalink)
Member: 2501288
Thanks Meter: 328
Pleas any solution to unbrick this device
Old 12-07-2016, 11:04   #4 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello. Atleast resolder eMMC flash.
Old 12-07-2016, 11:22   #5 (permalink)
Member: 2501288
Thanks Meter: 328
Can you explain why this happened pleas? . the phone state before flash power on and show problem in recovery
note i had two devices (g630-u20) with same problem , the first after flash with sd card mode work fine , and just i want to test i do flash for the other set with QLM and now dead
Old 12-07-2016, 13:22   #6 (permalink)
JayDi's Avatar
Member: 462970
It old Huawei. Thin board, bad eMMC.
Old 12-29-2016, 17:03   #7 (permalink)
farukpdm's Avatar
Member: 1417131
Sonork: Uninstalled
Thanks Meter: 1,090
can any one have backup file for this model
i have same problem
The Following User Says Thank You to farukpdm For This Useful Post:
Old 05-06-2017, 15:53   #8 (permalink)
Member: 2703335
Thanks Meter: 22
need backup firmware for this phone plz!
The Following User Says Thank You to MedjoHost For This Useful Post:
Page generated in 0.14815 seconds with 8 queries
