09-27-2016, 15:32 | #1 (permalink) |
Freak Poster Join Date: Feb 2014 Location: P A K I S T A N
Member: 2130135 Status: Offline Sonork: XXXXXXXXX Thanks Meter: 50 | qmobile I2 flashing done.By InfinityBox CM2SPD Chinese Miracle II [SPD module] v 1.22 Loading : QMobile_i2_MP.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : QMobile_i2_MP_ FastCheck : 0x0077949C65 Loading files ... File : fdl1.bin File : fdl2.bin File : nvitem.bin File : nvitem_wcn.bin File : u-boot-spl-16k.bin File : SC7702_sc7731g_band128.bin File : DSP_DM_G2.bin File : SC8800G_x30g_wcn_dts_modem.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : LOGO.bmp File : charge.bmp File : prodnv.img File : cache.img File : u-boot.bin File : SC7731_UMS.xml Load Ok! Operation : Flash [ v1.22 ] ======= Flash Files set for flashing : [ MCU ] : QMobile_i2_MP_ CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : QMobile_i2_MP File : fdl1.bin File : fdl2.bin File : nvitem.bin File : nvitem_wcn.bin File : u-boot-spl-16k.bin File : SC7702_sc7731g_band128.bin File : DSP_DM_G2.bin File : SC8800G_x30g_wcn_dts_modem.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : LOGO.bmp File : charge.bmp File : prodnv.img File : cache.img File : u-boot.bin 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 31 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x17 records PMTManager : PMT Update Ok! Flashing now [FlashProc] : ERASE Current ID : ERASEUBOOT Current Part : uboot [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : SPLLOADER Current File : u-boot-spl-16k.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_W Current File : SC7702_sc7731g_band128.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_W Current File : DSP_DM_G2.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_WCN Current File : SC8800G_x30g_wcn_dts_modem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOT Current File : boot.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : RECOVERY Current File : recovery.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : SYSTEM Current File : system.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : USERDATA Current File : userdata.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOTLOGO Current File : LOGO.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : FASTBOOT_LOGO Current File : charge.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH Current Part : wruntimenv1 [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH_WCN Current Part : wcnruntimenv1 [FlashProc] : Ok! [FlashProc] : CODE Current ID : PRODNV Current File : prodnv.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : CACHE Current File : cache.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEMISC Current Part : misc [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : UBOOTLOADER Current File : u-boot.bin Flashing now ... [FlashProc] : Ok! Elapsed: 00:05:55 Reconnect Power/Cable! |
The Following User Says Thank You to Lucky_gsm299 For This Useful Post: |
