04-14-2019, 08:24 | #1 (permalink) |
Insane Poster Join Date: Feb 2017
Member: 2688510 Status: Offline Thanks Meter: 7 | Qmobile i6i logo splash after flashing Scatter Load Ok , BaseBand : MT6580 , Project : s5030 , Storage : EMMC Files found : 9 , Set to Flash : 8 Ready to Flash! Start at : [4/8/2019 / 2:20:05 PM] Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 83 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100464A32374D42025332D684B2A5 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM72J [eMMC] : FLASH_CID : 150100464A32374D42025332D684B2A5 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xE5EE197ED4AB59AECB9CA46D012DAA35 INT RAM : 0x00020000 EXT RAM : 0x30000000 [768 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6580 , Project : s5030 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3425 mV BL : [WARNING] : BatteryLevel LOW!!! BL : Flash Pre-Erase Total blocks to Erase : 1 Erase : 0x0000000001C80000-0x00000000E6300000 Flash Pre-Erase Done, time used : 00:00:02 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s5030.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0014 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:03:01 Processing : Verify Verify Passed : LK Verify Passed : BOOT Verify Passed : RECOVERY Verify Passed : LOGO Verify Passed : SECRO Verify Passed : SYSTEM Verify Passed : CACHE Verify Passed : USERDATA Data Verify Done, time used : 00:00:02 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:20 Reconnect Power/Cable! |
04-14-2019, 14:09 | #3 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Charge battery first, flash correct variant firmware. Also make FlashIC test and check result. Br. Infinity-Box Team. |
