04-14-2009, 08:36 | #1 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 71603 Status: Offline Thanks Meter: 31 | I-Mobile 901 After flash Only White LCD Code: Loading file v.02... error: data error ! Loading failed, probably damaged data file. Code: COM4 [Serial2] selected Device: I-Mobile-901 Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active "format ffs" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6217:8A00]... CPU: MT6217 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98001B00000009:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... . detection phase #2... ................................................................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Area: Firmware flash: 98001B00000009:29EA0000000000 Write: Firmware detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization... formatting... flash: 98001B00000009:18000000000000 Finalization Done Finished, time used: 78 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
04-14-2009, 08:49 | #2 (permalink) |
Member: 71603 Status: Offline Thanks Meter: 31 | Here my flash backup file: http://www.4shared.com/file/98454804...092731B0X.html |
04-14-2009, 10:02 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, Flash phone with this file from support area: IMobile-901_MADDRTATH0TP7B50D_MADRID_HW_B4_Jun-30-2006_901P64-66-V10z-000-00_En_Th.B0M.bin Your phone has the same version. |
04-14-2009, 11:14 | #4 (permalink) |
Member: 71603 Status: Offline Thanks Meter: 31 | Thanks for Ur reply, before post I tryed flash 4 files from support site, but only white LCD: IMobile-901_MADDRTATH0TP7B50D_MADRID_HW_B4_Jun-28-2006_901P64-66-V10z-000-00-JUN-27-2006_En_Th.B0M IMobile-901_MADDRTATH0TP7B50D_MADRID_HW_B4_Jun-28-2006_901P64-66-V10z-XXX-XX-JUN-27-2006_En_Th.B0M IMobile-901_MADDRTATH0TP7B50D_MADRID_HW_B4_Jun-30-2006_901P64-66-V10z-000-00_En_Th.B0M IMobile-901_MADDRTATH0TP7B50D_MADRID_HW_B4_Jun-30-2006_901P64-66-V10z-XXX-XX_En_Th.B0M |
04-14-2009, 18:07 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, 1. Flash phone with this file from support area: IMobile-901_MADDRTATH0TP7B50D_MADRID_HW_B4_Jun-30-2006_901P64-66-V10z-000-00_En_Th.B0M.bin Your phone has the same version. 2. Try to use two repair eeprom files one by one. |
04-15-2009, 10:13 | #6 (permalink) |
Member: 71603 Status: Offline Thanks Meter: 31 | Flash with file name: IMobile-901_MADDRTATH0TP7B50D_MADRID_HW_B4_Jun-30-2006_901P64-66-V10z-000-00_En_Th.B0M.bin phone still white LCD only, Tryed eeprom file: IMobile-901_repair_eeprom_01.B0E or IMobile-901_repair_eeprom_02.B0E it is the same. How can i do, pls? |
04-17-2009, 12:17 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, I suggest you to check phone hardware due to IMobile-901_MADDRTATH0TP7B50D_MADRID_HW_B4_Jun-30-2006_901P64-66-V10z-000-00_En_Th.B0M.bin + IMobile-901_repair_eeprom_02.B0E is your original phone backup. If after flash with these files your phone still can not work well there is a reason to check phone hardware. |
need help wu800i after flashing only white blink | /\/\A/\/| | Sony Ericsson | 11 | 08-03-2009 21:01 |
E200 after flash only white screen!!help | dominik1 | NSPRO | 5 | 11-28-2008 17:17 |
sigmatel s1 after flash only white screen? | akt007 | SpiderMan | 1 | 11-13-2008 14:03 |
