06-13-2018, 11:54 | #1 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,640 | RDA & SCR fail read FW Code: Start at : [13-06-2018 / 12:33:56] Operation : Check Device / Info ======= Settings Settings : Read AllInfo is On Settings : Full Boot disabled by default Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : EB8CB316 Settings registers ... 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851B ==== FLASH FL_VEN : 60C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 Initial : 81C0024C Boot Done! Checking step #1, wait ... Checking step #2, wait ... Elapsed: 00:00:09 Done Reconnect Power/Cable! Finish at : [13-06-2018 / 12:34:06] ========================= Start ========================= 13-06-2018 / 12:35:58 ========================================================= Card found : S/N : 5C203D37 , v0137 Chinese Miracle II [RDA module] v 1.05 Start at : [13-06-2018 / 12:36:21] Operation : Check Device / Info ======= Settings Settings : Read AllInfo is On Settings : Full Boot disabled by default Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : EB8CB316 Settings registers ... 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851B ==== FLASH FL_VEN : 60C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 Initial : 81C0024C Boot Done! Checking step #1, wait ... Checking step #2, wait ... Elapsed: 00:00:20 Done Reconnect Power/Cable! Finish at : [13-06-2018 / 12:36:42] Start at : [13-06-2018 / 12:37:09] Operation : Check Device / Info ======= Settings Settings : Read AllInfo is Off Settings : Full Boot disabled by default Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : EB8CB316 Settings registers ... 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851B ==== FLASH FL_VEN : 60C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 Initial : 81C0024C Boot Done! Elapsed: 00:00:12 Done Reconnect Power/Cable! Finish at : [13-06-2018 / 12:37:22] Start at : [13-06-2018 / 12:37:39] Operation : Read FullFlash ======= Settings Settings : SafeMode is Off [Fast] Settings : Make IFF (MCU) file Settings : Make Calibration file Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Phone boot not done :( Reconnect Power/Cable! Finish at : [13-06-2018 / 12:38:09] Start at : [13-06-2018 / 12:38:19] Operation : Read FullFlash ======= Settings Settings : SafeMode is Off [Fast] Settings : Make IFF (MCU) file Settings : Make Calibration file Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : EB8CB316 Settings registers ... 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851B ==== FLASH FL_VEN : 60C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 Initial : 81C0024C ==== Booting Sending RamRun Loader ... Set : 8809 , 00400000 Use : 8809_00400000_usb.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Flush : 0400F000 Loader run Boot Done! Read Flash now ... Read Ok, 4194304 bytes read Verify file... SCR Code: Operation : Read Flash [ v1.03 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device Connected! |
06-13-2018, 12:15 | #3 (permalink) |
Member: 2680008 Status: Offline Thanks Meter: 1,640 | Read codes Works Code: Card found : S/N : 5C203D37 , v0137 Chinese Miracle II [RDA module] v 1.05 Operation : Read User Code Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : EB8CB316 Settings registers ... 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851B ==== FLASH FL_VEN : 60C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 Initial : 81C0024C ==== Booting Sending RamRun Loader ... Set : 8809 , 00400000 Use : 8809_00400000_usb.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Flush : 0400F000 Loader run Boot Done! Read UDA now , wait ... Read done, sorting EXTData Following items found : Item : CSW Item : NVRAM Required data found, extracting code UserCode : 1234 Elapsed: 00:00:14 Done Reconnect Power/Cable! Operation : Check Device / Info ======= Settings Settings : Read AllInfo is Off Settings : Full Boot disabled by default Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : EB8CB316 Settings registers ... 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851B ==== FLASH FL_VEN : 60C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 Initial : 81C0024C Boot Done! Elapsed: 00:00:28 Done Reconnect Power/Cable! |
06-13-2018, 15:14 | #6 (permalink) |
Member: 2680008 Status: Offline Thanks Meter: 1,640 | only native AV from microsoft MSE but excluded files and location c\:infinityBox excluded processes c\:infinityBox but sample on hand i try one more time and post result. |
06-13-2018, 15:33 | #7 (permalink) |
Member: 2680008 Status: Offline Thanks Meter: 1,640 | hello Code: Operation : Factory Area Rebuild [Repair IMEI] Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : EB8CB316 Settings registers ... 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851B ==== FLASH FL_VEN : 60C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 Initial : 81C0024C ==== Booting Sending RamRun Loader ... Set : 8809 , 00400000 Use : 8809_00400000_usb.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Flush : 0400F000 Loader run Boot Done! Read Factory Sector ... Read Ok , verify Detected 2 Sim Slot(s) Current Phone IMEI : IMEI1 : 355321011389039 IMEI2 : 355321011389047 New Phone IMEI : IMEI1 : 54677423466443-2 IMEI2 : 24535777866544-7 Build Factory Sector Write Factory Sector CSD WR : 81C05954 , 81C05968 CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Verify Factory Sector Sector Verifyed! IMEI Write Done! Elapsed: 00:00:21 Reconnect Power/Cable! Finish at : [13-06-2018 / 16:23:57] Start at : [13-06-2018 / 16:24:39] Operation : Read FullFlash ======= Settings Settings : SafeMode is Off [Fast] Settings : Make IFF (MCU) file Settings : Make Calibration file Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : EB8CB316 Settings registers ... 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851B ==== FLASH FL_VEN : 60C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 Initial : 81C0024C ==== Booting Sending RamRun Loader ... Set : 8809 , 00400000 Use : 8809_00400000_usb.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Flush : 0400F000 Loader run Boot Done! Read Flash now ... Read Ok, 4194304 bytes read Verify file... https://ibb.co/fo45AJ https://ibb.co/fZRVcy |
