01-10-2017, 14:37 | #1 (permalink) |
Freak Poster Join Date: Oct 2014 Location: black house
Member: 2280366 Status: Offline Thanks Meter: 19 | read pac file huawei Y5c failed i want to read pac file from this phone Y5c (y541-u02) that base on sc7731 but SPD module cant read pac file and it freeze on: [Info] : If SW freeze here more, than 15 seconds - remove cable i try with all loader and options but still i cant read info or pac file from this phone. please help me. here logs thanks |
01-11-2017, 08:53 | #6 (permalink) | |
Member: 2280366 Status: Offline Thanks Meter: 19 | Hello dear Jaydi i download that firmware from support but still i cant flash this phone. i try all loader and options but still failed and phone state is hang on honor logo please help me to revive this phone. Quote:
02-08-2018, 09:15 | #10 (permalink) |
No Life Poster Join Date: Feb 2011 Location: Android Modding
Member: 1507693 Status: Offline Thanks Meter: 131 | Me too i never been able to service this phone y541-u02 via infinity, software always freez no matter which boot i select, Even selecting flash file does not work, IS IT DRIVER PROBLEM ? Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 740 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! DS : Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 740 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! DS : Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! BUT IN SERVICE MODE IT SHOWS SOME INFO WITHOUT PRESSING BOOT KEYS Card found: S/N : 41645534 , v0136 Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC773x] eMMC [Generic 4.x-5.0] Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 740 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Phone Initial Info : Platform : MOCORTM_14B_TSHARK28_HUAWEI_W15.30_Debug Project : sc7731g_CP0_modem HWInfo : sc7731g_CP0_modem Compile : 07-20-2015 11:22:49 Phone Security Info : IMEI [1] : 869153020179807 IMEI [2] : 869153022679812 BT_ADDR : 000000000000 SelfInfo : BatVoltage : 4.74 V Done Reconnect Power/Cable! Loading : Y541-U02V100R001C567B105.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC7731_2341A PacVersion : Y541-U02V100R001C567B105 FastCheck : 0x005C906BAD Loading files ... File : fdl1-sign.bin File : fdl2-sign.bin File : nvitem_efuse.bin File : nvitem_wcn.bin File : u-boot-spl-16k-sign.bin File : SC7702_sc7731g_y560_efuse_AsiaPacific-sign.bin File : DSP_DM_G2-sign.bin File : SC8800G_x30g_wcn_dts_modem-sign.bin File : boot-sign.img File : recovery-sign.img File : system.img File : userdata.img File : boot_logo.bmp File : boot_logo.bmp File : sysinfo.img File : custom_SPC_SEA.img File : prodnv.img File : cache.img File : u-boot-sign.bin File : dlstat.bin File : globalinfo.img File : SC7731_2341A_efuse.xml Load Ok! Operation : Flash [ v1.27 ] ======= Flash Files set for flashing : [ MCU ] : Y541-U02V100R001C567B105.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC7731_2341A PacVersion : Y541-U02V100R001C567B105 File : fdl1-sign.bin File : fdl2-sign.bin File : nvitem_efuse.bin File : nvitem_wcn.bin File : u-boot-spl-16k-sign.bin File : SC7702_sc7731g_y560_efuse_AsiaPacific-sign.bin File : DSP_DM_G2-sign.bin File : SC8800G_x30g_wcn_dts_modem-sign.bin File : boot-sign.img File : recovery-sign.img File : system.img File : userdata.img File : boot_logo.bmp File : boot_logo.bmp File : sysinfo.img File : custom_SPC_SEA.img File : prodnv.img File : cache.img File : u-boot-sign.bin File : dlstat.bin File : globalinfo.img 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 740 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac Boot failed! Boot failed! Reconnect Power/Cable! Last edited by Fragga; 02-08-2018 at 09:23. |
