04-28-2021, 12:17 | #1 (permalink) | ||
No Life Poster Join Date: Oct 2017 Location: on google.com
Member: 2771307 Status: Offline Thanks Meter: 772 | Realme 8 can't connect to infinity cm2mt2 2.21 or 2.22 log from 2.22 software Quote:
log from 2.21 software with same problem Quote:
04-28-2021, 12:32 | #2 (permalink) |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | select preloader from factory firmware if you not have please contact me on telegram will try send https://t.me/kamal_singla |
The Following 3 Users Say Thank You to kamal_singla For This Useful Post: |
04-28-2021, 12:47 | #3 (permalink) | |
Member: 2771307 Status: Offline Thanks Meter: 772 | In this model must select preloader from factory firmware thanks to Mr. kamal_singla I got success Quote:
The Following 4 Users Say Thank You to IMEI_info For This Useful Post: |
04-28-2021, 13:14 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Also, on UFS case, may need make HWReport with UFS setting. In that case you dont need seek preloader. |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
04-28-2021, 13:28 | #5 (permalink) | ||
Member: 2771307 Status: Offline Thanks Meter: 772 | I tried already HW raport with UFS ticked but not help, upper is log from 2.21 and here from 2.22 Quote:
The Following User Says Thank You to IMEI_info For This Useful Post: |
04-28-2021, 17:24 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | EMI db updated. We will make it from next version updatable automatic too. |
The Following 5 Users Say Thank You to JayDi For This Useful Post: |
05-28-2021, 08:00 | #7 (permalink) | |
No Life Poster Join Date: Apr 2014 Location: istanbul
Member: 2171555 Status: Offline Thanks Meter: 129 | Quote:
Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.24 Load IDBase v524189 Ok! Update configuration ... Update Ok! Load IDBase v524189 Ok! Operation : SP Unlock [ v2.24 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM127) MODE : BOOTROM PORT : 127 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : D5D10D47AE61670CBFC6A3921161F3DC BROM : SecLevel : 0x000000E1 BROM : SecMode : SBC+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 7C79E02ECC4AE0E5A1143B475753AC7457998AFE272F148E4B B44B899504C5F2 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! DA : EMI : Failed to get EMI info from selected source! Boot done! Done! Elapsed: 00:00:15 Reconnect Power/Cable! Operation : SP Unlock [ v2.24 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM127) MODE : BOOTROM PORT : 127 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : D5D10D47AE61670CBFC6A3921161F3DC BROM : SecLevel : 0x000000E1 BROM : SecMode : SBC+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 7C79E02ECC4AE0E5A1143B475753AC7457998AFE272F148E4B B44B899504C5F2 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! DA : EMI : Failed to get EMI info from selected source! Boot done! Done! Elapsed: 00:03:10 Reconnect Power/Cable! Operation : HW Report [ v2.24 ] HWreport : Mode : UFS 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM124) MODE : BOOTROM PORT : 124 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : D5D10D47AE61670CBFC6A3921161F3DC BROM : SecLevel : 0x000000E1 BROM : SecMode : SBC+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 7C79E02ECC4AE0E5A1143B475753AC7457998AFE272F148E4B B44B899504C5F2 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! DA : EMI : Failed to get EMI info from selected source! Boot done! Memory Info : CID : 880103534C4433324755B9E1B624C6CF MEM : VEN : FORESEE | OEM : 301 | DEV : SLD32G DAT : Size: 29600 MB, Max.Speed: 52000 kHz, blklen(512), nblks(60620800), ro(0) EXT_CSD Info : EXT_CSD rev. : v1.8 ( MMC v5.1 ) CSD struct rev. : v1.2 Supported command sets : 1h HPI features : 1h BG operations support : 1h BG operations status : 0h Correct prg. sectors : 0h 1st init time after part. : 3000 ms Min. write perf.(DDR,52MH,8b): 0h Min. read perf. (DDR,52MH,8b): 0h TRIM timeout: 4 ms Secure feature support: 55h Secure erase timeout : 40500 ms Secure trim timeout : 25500 ms Access size : 3072 bytes HC erase unit size : 512 kbytes HC erase timeout : 1500 ms HC write prot grp size: 4096 kbytes HC erase grp def. : 0h Reliable write sect count: 1h Sleep current (VCC) : 7h Sleep current (VCCQ): 7h Sleep/awake timeout : 838860800 ns Sector count : 39d0000h Min. WR Perf. (52MH,8b): 0h Min. Read Perf.(52MH,8b): 0h Min. WR Perf. (26MH,8b,52MH,4b): 0h Min. Read Perf.(26MH,8b,52MH,4b): 0h Min. WR Perf. (26MH,4b): 0h Min. Read Perf.(26MH,4b): 0h Power class: 0 Power class(DDR,52MH,3.6V): 0h Power class(DDR,52MH,1.9V): 0h Power class(26MH,3.6V) : 0h Power class(52MH,3.6V) : 0h Power class(26MH,1.9V) : 0h Power class(52MH,1.9V) : 0h Part. switch timing : ah Out-of-INTR busy timing: 5h Card type : 57h Command set : 0h Command set rev.: 0h HS timing : 0h Bus width : 0h Erase memory content : 0h Partition config : 50h Boot partition size : 4096 kbytes Boot information : 7h Boot config protection: 0h Boot bus width : 2h Boot area write prot : 0h User area write prot : 0h FW configuration : 0h RPMB size : 4096 kbytes Write rel. setting : 1fh Write rel. parameter: 15h Start background ops : 0h Enable background ops: 2h H/W reset function : 1h HPI management : 0h Max. enhanced area size : 9a2h (10100736 kbytes) Part. support : 7h Part. attribute: 0h Part. setting : 0h General purpose 1 size : 0h (0 kbytes) General purpose 2 size : 0h (0 kbytes) General purpose 3 size : 0h (0 kbytes) General purpose 4 size : 0h (0 kbytes) Enh. user area size : 0h (0 kbytes) Enh. user area start: 0h Bad block mgmt mode: 0h Overall status : MLC status : Not defined SLC status : 0% - 10% used EOL status : Normal ( Less than 80% reserved blocks used ) Done! Elapsed: 00:00:17 Operation : SP Unlock [ v2.24 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM124) MODE : BOOTROM PORT : 124 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : D5D10D47AE61670CBFC6A3921161F3DC BROM : SecLevel : 0x000000E1 BROM : SecMode : SBC+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 7C79E02ECC4AE0E5A1143B475753AC7457998AFE272F148E4B B44B899504C5F2 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! DA : EMI : Failed to get EMI info from selected source! Boot done! Done! Elapsed: 00:00:29 Reconnect Power/Cable! Operation : SP Unlock [ v2.24 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM124) MODE : BOOTROM PORT : 124 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : D5D10D47AE61670CBFC6A3921161F3DC BROM : SecLevel : 0x000000E1 BROM : SecMode : SBC+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2028 | Manual : Disabled BROM : SOCID : 7C79E02ECC4AE0E5A1143B475753AC7457998AFE272F148E4B B44B899504C5F2 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! DA : EMI : Failed to get EMI info from selected source! Boot done! Done! Elapsed: 00:00:26 Reconnect Power/Cable! I have a wiko wiev4 lite phone in my hand. i am getting the same error. | |
