10-01-2021, 14:58 | #1 (permalink) |
No Life Poster Join Date: Mar 2011 Location: PAKISTAN
Member: 1537135 Status: Offline Thanks Meter: 1,021 | Realme C11 2021(RMX3231) sp9863a cannot read flash file i have many try but fail phone info full but same err >>> Error : Device NOT INITIALIZED ! Initialize it first via "IDENTIFY" ! >>> Make sure you have made "IDENTIFY" first! Card found : C1B4DF65 , v0150 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Identify [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... >>> Device not found! >>> Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Realme : RMX3231 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Device info : Product Brand : realme Product Device : RMX3231 Product Model : RMX3231 Patch Level : RP1A.201005.001 Display ID : RMX3231_11.A.23 SW OTA Version : RMX3231_11.A.23_202104062346 Ver. Incmt : 29 Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2021-03-05 Build Time : 06.04.2021 Product Info : RMX3231 Product Board : RMX3231 Board Platform : sp9863a Product Manfct : realme USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption ) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:00:35 Operation : Read FW [ v2.14 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Realme : RMX3231 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! >>> Error : Device NOT INITIALIZED ! Initialize it first via "IDENTIFY" ! >>> Make sure you have made "IDENTIFY" first! Reconnect Power/Cable! |
10-02-2021, 22:17 | #4 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | If you just need flash file .... RMX3231_11.A.37_202109041636 - factory latest stock rom. You can also try loading .pac file and repeat procedure ... b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
The Following 2 Users Say Thank You to Brka For This Useful Post: |
09-23-2022, 14:29 | #5 (permalink) | |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
am i doing sth wrong..? still not reading FW.. Identify; Code: Operation : Identify [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : RMX3231-user-native_SHARKL3_R11.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Device info : Product Brand : realme Product Device : RMX3231 Product Model : RMX3231 Patch Level : RP1A.201005.001 Display ID : RMX3231EU_11.A.78 SW OTA Version : RMX3231EU_11.A.78_202207191507 Ver. Incmt : 399 Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2022-07-05 Build Time : 19.07.2022 Product Info : RMX3231 Product Board : RMX3231 Board Platform : sp9863a Product Manfct : realme USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption ) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:00:44 Read FW; Code: Operation : Read FW [ v2.14 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : RMX3231-user-native_SHARKL3_R11.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! >>> Error : Device NOT INITIALIZED ! Initialize it first via "IDENTIFY" ! >>> Make sure you have made "IDENTIFY" first! Reconnect Power/Cable! | |
09-29-2022, 23:26 | #6 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | @LoveLess No idea yet. But you can try to select different loaders (ibstall CMeSP2 boot-pack) and try it one by one |
