02-18-2023, 06:56 | #1 (permalink) |
No Life Poster Join Date: Sep 2004 Location: coast Age: 53
Member: 83397 Status: Offline Thanks Meter: 204 | Realme c12 rmx2189 how to repair imei? PTFN: MTK USB Port (COM21) MODE: BOOTROM; PORT: 21 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init... Init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: FE8446663350BEE9BDC249E067A8AEA4 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 1A9736411404BC45CCEB1B9C47EF6E3325D0B67A3B7CF179E4 CD46E19CAF7CDC SLA: Local Auth SLA: Starting Auth SLA: Continue Auth SLA: Auth Passed; SEC: 0x000000E0 AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Transfer control to DA... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100445036384D4202C54FE89CB74D VEN: Samsung OEM: 0 ID: 445036384D42 [DP68MB] PRV: 0x02 SNN: 3310348444 [0xC54FE89C] MM/YY: 11/2020 EMI: Init EMI by INTERNAL Database EMI: FireFly preloader_oppo6765.bin with 13 memory type(s) supported 1. eMMC LP_DDR4X ID: 1501003458364B4D42 Ven: Samsung | Dev: 4X6KMB RAM: 0 B 2. eMMC LP_DDR4X ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 GB 3. eMMC LP_DDR4X ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 0 B 4. eMMC LP_DDR4X ID: 150100445036384D42 Ven: Samsung | Dev: DP68MB RAM: 3.00 GB 5. eMMC LP_DDR4X ID: 13014E47314A395238 Ven: Micron | Dev: G1J9R8 RAM: 4.00 GB 6. eMMC LP_DDR4X ID: 150100445836384D42 Ven: Samsung | Dev: DX68MB RAM: 3.00 GB 7. eMMC LP_DDR4X ID: 150100444836444142 Ven: Samsung | Dev: DH6DAB RAM: 0 B 8. eMMC LP_DDR4X ID: 13014E47314A395339 Ven: Micron | Dev: G1J9S9 RAM: 4.00 GB 9. eMMC LP_DDR4X ID: 150100445636444D42 Ven: Samsung | Dev: DV6DMB RAM: 0 B 10. eMMC LP_DDR4X ID: 450100444134313238 Ven: Sandisk | Dev: DA4128 RAM: 0 B 11. eMMC LP_DDR4X ID: 150100445636444142 Ven: Samsung | Dev: DV6DAB RAM: 0 B 12. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 0 B 13. eMMC LP_DDR4X ID: 90014A684445615033 Ven: Hynix | Dev: hDEaP3 RAM: 4.00 GB EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC CID: 150100445036384D4202C54FE89CB74D VEN: Samsung OEM: 0 ID: 445036384D42 [DP68MB] PRV: 0x02 SNN: 3310348444 [0xC54FE89C] MM/YY: 11/2020 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x01000000 [ 16.00 MB ] USER: 0xE8F800000 [ 58.24 GB ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: CA80C2DE252A98DA87A541E35C4A5ACA MEID: FE8446663350BEE9BDC249E067A8AEA4 USB: HIGH-SPEED Boot done [1] Reading... Ok NVRAM: Items: 0xAB Size: 0x08F8BF State: Ok WiFi MAC: F0625AAE29BB BlTh MAC: F0625AAE29BA Compatible mount points not found 1. Flash with good firmware may helps 2. Repair BB if need Reconnect Power/Cable now |
