08-13-2015, 22:09 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: "Alfa-Gsm"
Member: 507536 Status: Offline Thanks Meter: 75 | Repair Imei 6752 Code: Chinese Miracle II [MTK module] v 1.25 Operation : Check / Read Info [ v1.25 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 85 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6752 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6732|MT6752_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 15010051375853414201B6EFE40861D7 DA Stat : v4.2 on BBID : 0x8F DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BASX7 [eMMC] : FLASH_CID : 15010051375853414201B6EFE40861D7 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
08-14-2015, 07:41 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, MT6752 supported for repair security. Install driver from CM2MTK installed folder and try again. What is phone vid&pid? Also post log. Br. Br. |
08-14-2015, 16:01 | #3 (permalink) | |
Member: 507536 Status: Offline Thanks Meter: 75 | Drivers Problem Quote:
Code: Operation : Repair Security [ v1.25 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 36 ] Sync... Device boot not done Check Drivers Try again Init Service mode failed, something went wrong :( Reconnect Power/Cable! | |
08-14-2015, 18:06 | #5 (permalink) | |
Member: 507536 Status: Offline Thanks Meter: 75 | Repair Security Done, now another issue Quote:
Code: Operation : Repair Security [ v1.25 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 36 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6752 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6732|MT6752_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 15010051375853414201B6EFE40861D7 DA Stat : v4.2 on BBID : 0x8F DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BASX7 [eMMC] : FLASH_CID : 15010051375853414201B6EFE40861D7 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! IMEI [00] : 865583XXXXXXXX IMEI [01] : 865583XXXXXXXX Set IMEI [00] : 865583XXXXXXXX Set IMEI [01] : 865583XXXXXXXX Prepare finished. Security check required! Wait for phone... Phone found! [ 36 ] Sync... PostCheck Ok! Repair done! Done! Elapsed: 00:01:05 Reconnect Power/Cable! | |
08-14-2015, 21:13 | #8 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | You can always fix "=> TOOL DL image Fail!" with "Fix DL" button. It not kill user data or damage anything, just remove that message and allow phone boot. |
The Following 4 Users Say Thank You to JayDi For This Useful Post: |
