12-24-2009, 09:46 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: Tunisia
Member: 650956 Status: Offline Sonork: doki-doc gsm Thanks Meter: 72 | repair imei for s320X COM6 [VCP0] selected module v2.99 Device: Alcatel-S320X Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:120F:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000000:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info protocol ver: 05 ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000 code offset: 00000000 ffs offset/size: 00C00000/00400000 TCL-ID identification version: 16R provider: S320X-2CRGTE1 customization: CH16DD32 customization: XH16DD32 TCL-ID identification done ffs/eeprom address assigned: 00C00000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected customization: XH16DD32 customization name adjusted flash: 98000300000000:2AEA0000000000 flash: 98000300000000:2AEA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98000300000000:2AEA0000000000 flash: 98000300000000:2AEA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 98000300000000:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000000:2AEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S320X_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07 _36_SP1_V20__system_log__00000000_20091224-093456.B0X.bin Finished, time used: 251 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
12-24-2009, 09:49 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Try to flash phone with another firmware (newer). It may be that old firmware do not support your phone hardware type well and as a result imei can not be displayed well. Also you can try to reapair imei with "Write" button from software "Service" page. |
12-24-2009, 10:05 | #3 (permalink) |
Member: 650956 Status: Offline Sonork: doki-doc gsm Thanks Meter: 72 | i flashed phone with all version from support and with s219x all time rong imei i can't undrestind "Also you can try to reapair imei with "Write" button from software "Service" page." |
12-24-2009, 11:13 | #6 (permalink) |
Member: 650956 Status: Offline Sonork: doki-doc gsm Thanks Meter: 72 | sucsess with s319x "S319X-2GALGB1_XH16AE31_JRD23_07A_PCB01_GPRS_MT6223_S00[1].MAUI_07A_W07_36_SP1_V20_2009-02-04_En_Fr_De_Nl_Tr_simfree.B0M " flash\complet format\ repair \unlock . thank infinity teem |
The Following User Says Thank You to ziadi_alaeddin For This Useful Post: |
When will be avalible repair IMEI for U600 after repair flashing are only zero | wgmmmx | NSPRO | 1 | 06-05-2007 22:59 |
How repair imei for 6101 ? | nokiatwin | Universalbox | 4 | 07-24-2006 04:43 |
Repair imei for 2600 pls......... | zoki | Griffin | 0 | 06-07-2005 08:48 |
Remote Unlocking/Repairing/Imei For ALL Siemens Inc C45 and S45 | AlexG | Main Sales Section | 0 | 02-07-2002 00:22 |
