02-12-2022, 13:44 | #16 (permalink) |
No Life Poster Join Date: Jul 2010 Location: B.J.M Age: 36
Member: 1338323 Status: Offline Sonork: 100,1662431 Thanks Meter: 301 | Oppo A12 CPH2083 Unlock Pattern Lock, Password Without Data loss Code: Load IDBase v1121431 Ok! Update configuration ... Load IDBase v1121431 Ok! Operation : HW Report [ v2.33 ] HWreport : Mode : eMMC 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM52) MODE : BOOTROM PORT : 52 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 48FAF0D363E10D257B21593DD6D05C5F BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 1C9374D57A41F5151042C652DFFEBDEAFBDBE7B252AA6D122E8667EB3D9465BE BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 90014A68423861503E03003BBBB39741 EMMC: VEN : HYNIX : OEM : 74 : ID : 68423861503E : PRV : 0x03 EMMC: VEN : HYNIX : hB8aP> EMMC: SNN : 3914675 ( 0x003BBBB3 ) , MF : 9/2020 EMI : DEV : FireFly EMI : SRC : preloader_oppo6765_19451.bin EMI : CNT : 000A EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 90014A68423861503E03003BBBB39741 EMMC: VEN : HYNIX : OEM : 74 : ID : 68423861503E : PRV : 0x03 EMMC: VEN : HYNIX : hB8aP> EMMC: SNN : 3914675 ( 0x003BBBB3 ) , MF : 9/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : BE741078244F9D2CAB0D81F15908D1F5 DA : USB : HIGH-SPEED Boot done! Memory Info : CID : 90014A68423861503E03003BBBB39741 MEM : VEN : HYNIX | OEM : 4A01 | DEV : hB8aP> DAT : Size: 29820 MB, Max.Speed: 52000 kHz, blklen(512), nblks(61071360), ro(0) EXT_CSD Info : EXT_CSD rev. : v1.8 ( MMC v5.1 ) CSD struct rev. : v1.2 Supported command sets : 1h HPI features : 1h BG operations support : 1h BG operations status : 0h Correct prg. sectors : 0h 1st init time after part. : 1000 ms Min. write perf.(DDR,52MH,8b): 0h Min. read perf. (DDR,52MH,8b): 0h TRIM timeout: 0 ms Secure feature support: 55h Secure erase timeout : 150000 ms Secure trim timeout : 150000 ms Access size : 3584 bytes HC erase unit size : 512 kbytes HC erase timeout : 600 ms HC write prot grp size: 8192 kbytes HC erase grp def. : 0h Reliable write sect count: 1h Sleep current (VCC) : 8h Sleep current (VCCQ): 9h Sleep/awake timeout : 419430400 ns Sector count : 3a3e000h Min. WR Perf. (52MH,8b): 78h Min. Read Perf.(52MH,8b): 8ch Min. WR Perf. (26MH,8b,52MH,4b): 46h Min. Read Perf.(26MH,8b,52MH,4b): 46h Min. WR Perf. (26MH,4b): 1eh Min. Read Perf.(26MH,4b): 1eh Power class: 0 Power class(DDR,52MH,3.6V): 0h Power class(DDR,52MH,1.9V): 0h Power class(26MH,3.6V) : 0h Power class(52MH,3.6V) : 0h Power class(26MH,1.9V) : 0h Power class(52MH,1.9V) : 0h Part. switch timing : 1h Out-of-INTR busy timing: ah Card type : 57h Command set : 0h Command set rev.: 0h HS timing : 0h Bus width : 0h Erase memory content : 0h Partition config : 48h Boot partition size : 4096 kbytes Boot information : 7h Boot config protection: 0h Boot bus width : 2h Boot area write prot : 0h User area write prot : 0h FW configuration : 0h RPMB size : 16384 kbytes Write rel. setting : 1fh Write rel. parameter: 15h Start background ops : 0h Enable background ops: 2h H/W reset function : 1h HPI management : 0h Max. enhanced area size : 747h (15261696 kbytes) Part. support : 7h Part. attribute: 0h Part. setting : 0h General purpose 1 size : 0h (0 kbytes) General purpose 2 size : 0h (0 kbytes) General purpose 3 size : 0h (0 kbytes) General purpose 4 size : 0h (0 kbytes) Enh. user area size : 0h (0 kbytes) Enh. user area start: 0h Bad block mgmt mode: 0h Overall status : MLC status : 0% - 10% used SLC status : Not defined EOL status : Normal ( Less than 80% reserved blocks used ) RPMB : RPMB KEY PROGRAMMED [UNUSABLE] STORAGE : OTP Status : UNLOCKED! Done! Elapsed: 00:00:56 Operation : Reset Settings/Format FS [ v2.33 ] Mode : SMART RESET DATA SAFE 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM52) MODE : BOOTROM PORT : 52 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 48FAF0D363E10D257B21593DD6D05C5F BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 1C9374D57A41F5151042C652DFFEBDEAFBDBE7B252AA6D122E8667EB3D9465BE BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 90014A68423861503E03003BBBB39741 EMMC: VEN : HYNIX : OEM : 74 : ID : 68423861503E : PRV : 0x03 EMMC: VEN : HYNIX : hB8aP> EMMC: SNN : 3914675 ( 0x003BBBB3 ) , MF : 9/2020 EMI : DEV : FireFly EMI : SRC : preloader_oppo6765_19451.bin EMI : CNT : 000A EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 90014A68423861503E03003BBBB39741 EMMC: VEN : HYNIX : OEM : 74 : ID : 68423861503E : PRV : 0x03 EMMC: VEN : HYNIX : hB8aP> EMMC: SNN : 3914675 ( 0x003BBBB3 ) , MF : 9/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : BE741078244F9D2CAB0D81F15908D1F5 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x815757 SafeFormat Ok : Oppo Done! Elapsed: 00:02:17 Reconnect Power/Cable! |
The Following 4 Users Say Thank You to bidhan_mobile For This Useful Post: |
02-13-2022, 06:42 | #17 (permalink) | |
No Life Poster Join Date: Dec 2009 Location: pakistan
Member: 1189561 Status: Offline Thanks Meter: 743 | y91 test report data safe done Quote:
The Following User Says Thank You to M.AKHTER For This Useful Post: |
02-17-2022, 14:38 | #18 (permalink) |
No Life Poster Join Date: Nov 2013 Location: pakistan P G L Age: 39
Member: 2067643 Status: Offline Sonork: 1611265 Thanks Meter: 474 | Operation : Identify [ v2.32 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM38) MODE : BOOTROM PORT : 38 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 07B4EA71EFD2A7FB21E1939654EE6F72 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : D0D67FB5A23648F0B63CA41C18E7BB15D53BB331E2F2550678 F186D481761CCF BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k65v1_64_bsp.bin EMI : CNT : 000C EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 150100445036444142025776D240A8C9 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 445036444142 EMMC: VEN : SAMSUNG : DP6DAB EMMC: SNN : 1467404864 ( 0x5776D240) , MF : 10/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 28163D3C75B99CD02B877CF0DE01AFE1 DA : USB : HIGH-SPEED Boot done! Product Brand : vivo Product Device : 2111 Product Model : V2111 Product Name : 2111N Patch Level : RP1A.200720.012 Display ID : RP1A.200720.012 release-keys Product Info : k65v1_64_bsp Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2022-01-01 Build Time : 13.01.2022 Product Board : k65v1_64_bsp Board Platform : mt6765 Product Manfct : vivo USERDATA : FILESYSTEM : EXT4 with FBE ( File-Base Encryption ) NVRAM : BBK_R0MP1_K65V1_64_BSP_MDBIN_PCB01_MT6765_S00.MOLY _LR12A_R3_MP_V136_6_P107 NVRAM : 0xB40AF781 NVRAM : State : Ok! INFO : WiFi MAC : 38384BC1B048 INFO : BlTh MAC : 38384BC1B047 INFO : IMEI[1] : 862841051964256 INFO : IMEI[2] : 862841051964249 Backup sensetive data [ 17 ] Backup path : Backup\MT6765__07B4EA71EFD2A7FB21E1939654EE6F72\ [33] Read : NVRAM [10] Read : NVDATA [23] Read : PROINFO [34] Read : LK [9] Read : NVCFG [18] Read : PROTECT1 [1] Read : PGPT [21] Read : PERSIST [0] Read : PRELOADER Backup done! STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY PROGRAMMED [UNUSABLE] PRELOADER : DEVICE : DEV : MT6765 NME : preloader_k65v1_64_bsp.bin CNT : 000C EMI : [00] : eMMC : LP_DDR4X : ID : 150100445836384D42 : VEN : SAMSUNG | DEV : DX68MB : RAM : [ 3.00 GB ] EMI : [01] : eMMC : LP_DDR4X : ID : 13014E47314A395339 : VEN : MICRON | DEV : G1J9S9 : RAM : [ 4.00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 150100445636444D42 : VEN : SAMSUNG | DEV : DV6DMB : RAM : [ 4.00 GB ] EMI : [03] : eMMC : LP_DDR4X : ID : 150100444436384D42 : VEN : SAMSUNG | DEV : DD68MB : RAM : [ 3.00 GB ] EMI : [04] : eMMC : LP_DDR4X : ID : 150100444836444142 : VEN : SAMSUNG | DEV : DH6DAB : RAM : [ 4.00 GB ] EMI : [05] : eMMC : LP_DDR4X : ID : 90014A684339615033 : VEN : HYNIX | DEV : hC9aP3 : RAM : [ 4.00 GB ] EMI : [06] : eMMC : LP_DDR4X : ID : 150100445636444142 : VEN : SAMSUNG | DEV : DV6DAB : RAM : [ 4.00 GB ] EMI : [07] : eMMC : LP_DDR4X : ID : 150100445036444142 : VEN : SAMSUNG | DEV : DP6DAB : RAM : [ 4.00 GB ] EMI : [08] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 4.00 GB ] EMI : [09] : eMMC : LP_DDR4X : ID : 13014E53304A394B39 : VEN : MICRON | DEV : S0J9K9 : RAM : [ 4.00 GB ] EMI : [0A] : eMMC : LP_DDR4X : ID : 150100445036444242 : VEN : SAMSUNG | DEV : DP6DBB : RAM : [ 4.00 GB ] EMI : [0B] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] PRELOADER saved to : Backup\PRELOADER\preloader_k65v1_64_bsp.bin Done! Elapsed: 00:00:34 Operation : Reset Settings/Format FS [ v2.32 ] Mode : SMART RESET DATA SAFE 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM38) MODE : BOOTROM PORT : 38 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 07B4EA71EFD2A7FB21E1939654EE6F72 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : D0D67FB5A23648F0B63CA41C18E7BB15D53BB331E2F2550678 F186D481761CCF BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k65v1_64_bsp.bin EMI : CNT : 000C EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 150100445036444142025776D240A8C9 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 445036444142 EMMC: VEN : SAMSUNG : DP6DAB EMMC: SNN : 1467404864 ( 0x5776D240) , MF : 10/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 28163D3C75B99CD02B877CF0DE01AFE1 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x835757 SafeFormat Ok : VIVO Done! Elapsed: 00:00:25 Reconnect Power/Cable! butt no lock remove |
The Following User Says Thank You to iftikharrana58 For This Useful Post: |
03-28-2022, 10:49 | #19 (permalink) |
Registered User Join Date: Aug 2016 Location: Multan Pakistan
Member: 2608490 Status: Offline Thanks Meter: 921 | oPPo A5s CPH1909 Data Safe Success By CM2 Identify Code: Operation : Identify [ v2.34 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM18) MODE : BOOTROM PORT : 18 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : BC83D9F85F0DDBFA2935C982136DC0EF BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 99F07F2ADA39A2C9E6AC7CE1D551DE5460DA1B4AC8A0F0CAA4283E401989670A BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 150100474436424D420105A20723C63F EMMC: VEN : SAMSUNG : OEM : 0 : ID : 474436424D42 : PRV : 0x01 EMMC: VEN : SAMSUNG : GD6BMB EMMC: SNN : 94504739 ( 0x05A20723 ) , MF : 12/2019 EMI : DEV : FireFly EMI : SRC : preloader_oppo6765_18511.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 150100474436424D420105A20723C63F EMMC: VEN : SAMSUNG : OEM : 0 : ID : 474436424D42 : PRV : 0x01 EMMC: VEN : SAMSUNG : GD6BMB EMMC: SNN : 94504739 ( 0x05A20723 ) , MF : 12/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 1BAB0CD885341A5CD83FA30097615E09 DA : USB : HIGH-SPEED Boot done! Patch Level : O11019 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2021-04-05 Product Manfct : OPPO Build Time : 19.03.2021 Product Brand : OPPO Product Model : CPH1909 Product Info : CPH1909 Product Device : CPH1909 Product Name : CPH1909 SW OTA Version : CPH1909EX_11.A.46_0460_202103191930 Display ID : CPH1909EX_11_A.46 Kernel Info : 4.9.77 Device UID : MT6765__CPH1909EX_11_A.30_191026_3c30b5de USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption *) NVRAM : OPPO6765_18511_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R2_TC16_SP_V50_5_P97 NVRAM : 0xBC0ACB13 NVRAM : State : Ok! INFO : WiFi MAC : AA0000000000 INFO : BlTh MAC : 9C5F5A90DA66 Backup sensetive data [ 18 ] Backup path : Backup\MT6765__BC83D9F85F0DDBFA2935C982136DC0EF\ [27] Read : NVRAM [11] Read : NVDATA [18] Read : PROINFO [28] Read : LK [10] Read : NVCFG [13] Read : PROTECT1 [1] Read : PGPT [16] Read : PERSIST [0] Read : PRELOADER [7] Read : OPPO_CUSTOM Backup done! STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY PROGRAMMED [UNUSABLE] PRELOADER : DEVICE : DEV : MT6765 NME : preloader_oppo6765_18511.bin CNT : 0009 EMI : [00] : eMMC : DDR3 : ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2.00 GB ] EMI : [01] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2.00 GB ] EMI : [02] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3.00 GB ] EMI : [03] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ] EMI : [04] : eMMC : DDR3 : ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4.00 GB ] EMI : [05] : eMMC : DDR3 : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4.00 GB ] EMI : [06] : eMMC : DDR3 : ID : 150100475036424D42 : VEN : SAMSUNG | DEV : GP6BMB : RAM : [ 3.00 GB ] EMI : [07] : eMMC : DDR3 : ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ] EMI : [08] : eMMC : DDR3 : ID : 150100514436334D42 : VEN : SAMSUNG | DEV : QD63MB : RAM : [ 2.00 GB ] PRELOADER saved to : Backup\PRELOADER\preloader_oppo6765_18511.bin Done! Elapsed: 00:00:32 Safe Reset Code: Operation : Reset Settings/Format FS [ v2.34 ] Step 1 Mode : SMART RESET DATA SAFE 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM18) MODE : BOOTROM PORT : 18 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : BC83D9F85F0DDBFA2935C982136DC0EF BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 99F07F2ADA39A2C9E6AC7CE1D551DE5460DA1B4AC8A0F0CAA4283E401989670A BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 150100474436424D420105A20723C63F EMMC: VEN : SAMSUNG : OEM : 0 : ID : 474436424D42 : PRV : 0x01 EMMC: VEN : SAMSUNG : GD6BMB EMMC: SNN : 94504739 ( 0x05A20723 ) , MF : 12/2019 EMI : DEV : FireFly EMI : SRC : preloader_oppo6765_18511.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 150100474436424D420105A20723C63F EMMC: VEN : SAMSUNG : OEM : 0 : ID : 474436424D42 : PRV : 0x01 EMMC: VEN : SAMSUNG : GD6BMB EMMC: SNN : 94504739 ( 0x05A20723 ) , MF : 12/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 1BAB0CD885341A5CD83FA30097615E09 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x805757 STEP 2 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM18) MODE : BOOTROM PORT : 18 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : BC83D9F85F0DDBFA2935C982136DC0EF BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 99F07F2ADA39A2C9E6AC7CE1D551DE5460DA1B4AC8A0F0CAA4283E401989670A BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 150100474436424D420105A20723C63F EMMC: VEN : SAMSUNG : OEM : 0 : ID : 474436424D42 : PRV : 0x01 EMMC: VEN : SAMSUNG : GD6BMB EMMC: SNN : 94504739 ( 0x05A20723 ) , MF : 12/2019 EMI : DEV : FireFly EMI : SRC : preloader_oppo6765_18511.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 150100474436424D420105A20723C63F EMMC: VEN : SAMSUNG : OEM : 0 : ID : 474436424D42 : PRV : 0x01 EMMC: VEN : SAMSUNG : GD6BMB EMMC: SNN : 94504739 ( 0x05A20723 ) , MF : 12/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 1BAB0CD885341A5CD83FA30097615E09 DA : USB : HIGH-SPEED Boot done! SafeFormat Ok! Done! Elapsed: 00:05:20 Reconnect Power/Cable! |
The Following User Says Thank You to GSM AR For This Useful Post: |
04-03-2022, 09:37 | #20 (permalink) |
Junior Member Join Date: Jun 2014 Location: dhaka
Member: 2197658 Status: Offline Thanks Meter: 12 | Operation : Reset Settings/Format FS [ v2.34 ] Mode : SMART RESET DATA SAFE 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM41) MODE : BOOTROM PORT : 41 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 CODE : Lafite TYPE : MODERN [RAPHAEL] BROM : MEID : 31ED76CD2395CC7EE6AC592640743A3F BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 1CC07FC4DC173A319DE14A5FD26276E6181F5D0EBB4E2E88F4 23CEAD2C897BDD BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6779 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! UFS: CE014B4D3856373030314A4D2D423831 UFS: VEN : 0x01CE | KM8V7001JM-B81 ( 1200 ) EMI : DEV : FireFly EMI : SRC : preloader_oppo6779.bin EMI : CNT : 000D EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x200000000 [ 8.00 GB ] UFS: CE014B4D3856373030314A4D2D423831 UFS: VEN : 0x01CE VID : KM8V7001JM-B81 IFW : 1200 LU0 : 0x00400000 [ 4.00 MB ] LU1 : 0x00400000 [ 4.00 MB ] LU2 : 0x1DCB000000 [ 119.17 GB ] FSN : 3c0c39e4cd1d REG : 0x202010000 CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 4D90202F94C4FA57E54AD247E1536C0C DA : USB : HIGH-SPEED Boot done! SmartInfo : Failed to detect! Info : Device is not supported yet! >>> Send log and report.log (if exists) to support! Include device info also! Reconnect Power/Cable! |
The Following User Says Thank You to gsm_rony For This Useful Post: |
