Old 03-07-2016, 08:02   #1 (permalink)
Shani3's Avatar
Member: 1582572
Sonork: 100.1609641
Thanks Meter: 573
qmobile format ?
Start at : [3/7/2016 / 11:31:49 AM]
Operation : Check/Read Info [ v1.15 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
==== Wait for phone...
Phone found! [ 39 ]
Port Opened
Sync...
Initial Boot Failed!
Reconnect Power/Cable!
Finish at : [3/7/2016 / 11:32:06 AM]
Start at : [3/7/2016 / 11:32:09 AM]
3. Insert cable
Phone found! [ 38 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7730/7731 eMMC Loader v1.1 Inf
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Unknown structure detected! Check correct model selection!
Elapsed: 00:00:15
Finish at : [3/7/2016 / 11:32:24 AM]
Old 03-07-2016, 08:17   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello. Select correct boot ( there is few one ) if you not want/not understand/or have own reason to NOT try do it - tick "reset in SVC" and do format again.
Old 03-07-2016, 08:19   #3 (permalink)
Member: 2195211
Thanks Meter: 4,294,967,295
which qmobile is it?
Old 03-07-2016, 08:47   #4 (permalink)
Shani3's Avatar
Member: 1582572
Sonork: 100.1609641
Thanks Meter: 573
qmobile W50
shnai
Old 03-07-2016, 09:13   #5 (permalink)
JayDi's Avatar
Member: 462970
Again :
http://forum.gsmhosting.com/vbb/11675407-post2.html
Old 03-07-2016, 09:18   #6 (permalink)
Shani3's Avatar
Member: 1582572
Sonork: 100.1609641
Thanks Meter: 573
Finish at : [3/7/2016 / 12:49:14 PM]
Start at : [3/7/2016 / 12:50:03 PM]
Operation : Format File System / Reset Settings [ v1.15 ]
Settings : SmartFormat is On
2. Insert cable
3. In case of SVC init problems - connect with hold "VolDown" button!
Phone found! [ 38 ]
Open Port Failed!
Finish at : [3/7/2016 / 12:50:13 PM]
Start at : [3/7/2016 / 12:50:29 PM]
2. Insert cable
Phone found! [ 38 ]
Open Port Failed!
Finish at : [3/7/2016 / 12:50:32 PM]
Start at : [3/7/2016 / 12:50:43 PM]
2. Insert cable
Phone found! [ 38 ]
Port Opened
Sync...
Normal Mode init
Sync...
========================= Start =========================
3/7/2016 / 12:52:13 PM
Card found: S/N : 533B1BFE , v0130
Chinese Miracle II [SPD module] v 1.15
Start at : [3/7/2016 / 12:53:03 PM]
2. Insert cable
Phone found! [ 38 ]
Port Opened
Sync...
Normal Mode init
Sync...
3/7/2016 / 12:54:35 PM
Start at : [3/7/2016 / 12:55:20 PM]
2. Insert cable
Phone found! [ 38 ]
Port Opened
Sync...
Normal Mode init
Sync...
3/7/2016 / 12:56:16 PM
Start at : [3/7/2016 / 1:02:26 PM]
2. Insert cable
Phone found! [ 38 ]
Port Opened
Sync...
Normal Mode init
Sync...
Old 03-07-2016, 09:22   #7 (permalink)
JayDi's Avatar
Member: 462970
Now try install driver one more time.
Read software advise and finish with that phone.
Old 03-07-2016, 09:29   #8 (permalink)
Member: 2195211
this phone have 7731 spd 5.0 ver and still i think no supported
Old 03-07-2016, 11:24   #9 (permalink)
JayDi's Avatar
Member: 462970
SVC mode IS NOT DEPEND ON CPU/ANDROID VERSION.
Old 03-07-2016, 12:56   #10 (permalink)
Member: 2195211
sir i also tried all cpu but it does not boot i dont know how to solve it
Old 03-07-2016, 14:41   #11 (permalink)
JayDi's Avatar
Member: 462970
If you can't connect phone in SVC mode - then no luck to finish operation.
Old 03-08-2016, 10:25   #12 (permalink)
Member: 2195211
plz check this phone to work it
Page generated in 0.17797 seconds with 8 queries
