Old 01-30-2016, 19:50   #1 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
CM2 Team Plz Add 6531 New Cpu Format , Pasword Read
Old 01-31-2016, 06:11   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
There is no any "new" cpu forma t of 6531.
Exists few flash types, which not supported. Since 2 year no any user send us such phone for adding.
I not see reason collect dozen of spd6531 phones for find this one.
Old 01-31-2016, 07:04   #3 (permalink)
kbgsm2014's Avatar
Member: 2140248
Thanks Meter: 166
Dear 6531 CPU already supported by CM2 here is VGO TEL i250 Read Flash,Format Logs
Read Flash
Operation : Read FullFlash [ v1.13 ]
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
 ====  Wait for phone...
Phone found! [ 13 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2 ¿A  Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00C8 0060 0016 0000
[0] Flash VEN : GigaDevice , GD25LQ32
[0] Flash CAP : 00400000
Read Flash Content
Read Ok , collect info
Set FileInfo :
Model Vendor : VGO TEL
Model Name   : i250
ExtInfo Data : English
Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_GD25LQ32_English__VGO TEL-i250_2.bin
Done!
Elapsed: 00:00:51
Format
Operation : Format File System [ v1.13 ]
Settings : SmartFormat is On
3. Insert battery
Phone found! [ 13 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ver : Spreadtrum Boot Block version 1.2 ‘*Boot Ok
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:00:11
The Following User Says Thank You to kbgsm2014 For This Useful Post:
Old 01-31-2016, 08:45   #4 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
3. Insert battery
Phone found! [ 24 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ver : SEND_ERROR_RSP(0x97) func:_FDL_HWInit, line:458
3è~~       Boot Ok
New Flash CPU 6531 Not Support
Old 01-31-2016, 08:48   #5 (permalink)
JayDi's Avatar
Member: 462970
There is no extrasenses.
So, if you want some help - start from FULL explaining - mode, type and etc.
Page generated in 0.18816 seconds with 8 queries
