09-28-2019, 16:04 | #1 (permalink) |
No Life Poster Join Date: Sep 2009 Location: pakistan
Member: 1119917 Status: Offline Sonork: nedi Thanks Meter: 190 | Rivo saphire s500 mt6261 dead after format with cm2 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 135 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 3DE5E2CE4BF8200BAB3204690EC1CB44 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32 [0] : FLASH_DIE : 00C8 0060 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup exists , skip Executing FFS FORMAT now... FAT_RANGE : 0x003C8000-0x003FDFFF , LEN : 0x00036000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:07 Reconnect Power/Cable! set was security code and now dead just charging show but when turn on only screen blan i tried flash full from a file but result is same. |
09-28-2019, 16:06 | #2 (permalink) | |
No Life Poster Join Date: Oct 2015 Location: Pakistan
Member: 2478233 Status: Offline Thanks Meter: 596 | Quote:
09-28-2019, 16:12 | #3 (permalink) | |
Member: 1119917 Status: Offline Sonork: nedi Thanks Meter: 190 | just blank lcd nothing show Quote:
before set was ok and just user code locked and it happens after format with cm2 | |
