01-30-2010, 17:07 | #1 (permalink) |
No Life Poster Join Date: May 2004 Age: 54
Member: 66136 Status: Offline Thanks Meter: 200 | Samsung P528 network 1 and 2 I'am new in chines phone, I have one Samsung P528 with 2 sim card, one network don't work, but 2 other network of the country work ? if I change the IMEI can this help me or no pls, because on phone : - the IMEI start with : 13579024xxxxx - back of battery have IMEI : 3505280800xxxxx maybe this phone have 2 imei like phone with 2 simcard. and anny one can help me with pintout pls, I have pinfinder but don't find the pinout, Best Regards, JAVA Good. |
01-30-2010, 19:45 | #2 (permalink) |
Member: 66136 Status: Offline Thanks Meter: 200 | hello all, I use my tester and find ( normaly ) Tx and Rx, but can't read information of phone, anny one have idea pls, I put 2 sim card, and on one network when I go for calibrate the network the phone show and error with MTK message ? Best Regards, JAVA Good. |
01-30-2010, 21:50 | #5 (permalink) |
Member: 66136 Status: Offline Thanks Meter: 200 | tks for the inforlmation about 2.8, because I forget and search the picture on my file but don't find it, with information for find Tx and Rx, and about MCU I think is a 6225 like on this message, but not sure, I see again the phone tomorow and post result, and big tks for your reply and help with RJ45 cable with + and - of pinfinder I can't power on the phone, this is normal ? Best Regards, JAVA Good. |
01-31-2010, 08:56 | #6 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,537 | Quote:
if you cant power it On using pinfinder power- pinout search is useless. try to find why this is happening. Did you modify your main infinity box by removing and shortcutting diode? this procedure is described in Pinfinder User Manual, trubleshooting section | |
01-31-2010, 14:26 | #7 (permalink) |
Member: 66136 Status: Offline Thanks Meter: 200 | tks for your reply, I don't use Pinfinder all the time, and sorry for don't know this information about modify my box, I see this about 1 year ago, but never search what is it. so my box is an Dual output, I need cut the diode and put a small cable ? and just before this cutting, it's normaly I have about 4,5v on power cable of pinfinder ? even I have this I need change cut this diode ? Dual output box.jpg I open my phone and it's a : MT6225A 0831 - ABTL KTFU9300 mt6225_.jpg tks in advance for your help and reply, Best Regards, JAVA Good. |
01-31-2010, 19:29 | #8 (permalink) |
Member: 66136 Status: Offline Thanks Meter: 200 | I open my Dual output box and cut the diode like the manuel, now my phone phone can power on but power after 4 seconds, so I need modify add a capacitor 1000 mf on my pinfinder box ? I have this box : IMAG0059.jpg IMAG0060.jpg tks in advance for your reply, Best Regards, JAVA Good. |
02-01-2010, 11:19 | #12 (permalink) | |
Member: 66136 Status: Offline Thanks Meter: 200 | tks again, I use the L20A cable and find pinout and I read the phone with small cable between GND batterie connector AND GND or RJ45 cable of pinfinder (and I have a small idea about GND I share it after reseolve this probleme), there the logs of this phone :* Quote:
picture of Pinfinder : pinfinder.gif so now what is the best way for for resolve the network probleme, format FFS, flash the phone ? or what pls ? Best Regards, JAVA Good. | |
02-01-2010, 11:25 | #14 (permalink) |
Member: 66136 Status: Offline Thanks Meter: 200 | I think I find the flash file, but need some information, they have only one file for 2 CPU or ?, and they have eeprom file too or no pls ? flash file.gif Best Regards, JAVA Good. |
02-01-2010, 11:36 | #15 (permalink) |
Member: 66136 Status: Offline Thanks Meter: 200 | tks for your reply algerienbox, you tell me repair IMEI you mean change it, because have one network work good and other don't work ? and if I save the flash file and eeprom, can play with it and restore all in the and, it's my first chines phone, if you are Algerian like on your name, I think you have many of this phones in your country, anny information is welcom . Best Regards, JAVA Good. |
