04-09-2009, 06:08 | #1 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Iassy Age: 59
Member: 19723 Status: Offline Thanks Meter: 359 | S320x problem I wrote eeprom and the same . I tried to change IMEI but it gives me something about new version . Thanx ! |
04-09-2009, 11:39 | #3 (permalink) |
Member: 19723 Status: Offline Thanks Meter: 359 | I didn't say that the phone doesn't power on . The phone powers on and got bad IMEI . unknown firmware, read flash and send to support That's what I get when I try to change IMEI . I wrote 2 flash files from support . Thanx ! |
04-10-2009, 10:24 | #8 (permalink) |
Member: 19723 Status: Offline Thanks Meter: 359 | ==== log opened: [4/9/2009 1:32:52 PM] ==== Application: D:\Program Files\InfinityBox\MModule\MModule.exe Loading data, wait... [Infinity Box] v2.69 S/N: xxxx:xxxx Wait... Device: Alcatel-S320X Done Imei 352........... already was repaired: 4/9/2009-1:32:06 PM Continue with this imei ? ==== log: [4/9/2009 1:33:22 PM] ==== COM4 [VCP3] selected module v2.69 Device: Alcatel-S320X Checking data, wait... advanced flash detection enabled Action: "repair imei" new imei: 352............... Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:2732:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000000:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 05 ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000 ffs offset/size: 00C00000/00400000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: disabled security area (code #3, part #2) calculation... customization: CH16BJ20 done flash: 98000300000000:2AEA0000000000 flash: 98000300000000:2AEA0000000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... use default security area (code #3, part #1) pattern ..................security area (code #3, part #1) detecting size... security area (code #3, part #1) detecting parameters... security area (code #3, part #1) encoding... done flash: 98000300000000:2AEA0000000000 flash: 98000300000000:2AEA0000000000 Write: security area (code #3, part #1) security area (code #3, part #1) calculation done Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 98000300000000:2AEA0000000000 Backup required data Done Patch required data ... ................................................ ................................................ ................................................ unknown firmware, read flash and send to support Patch required data Fail file saved: D:\Program Files\InfinityBox\MModule\backup_security\system_l og__JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_3 6_SP1_V20.BIN_FFFFFFFF_20090409-133830.B0X.bin Finished, time used: 294 sec Remove/Install battery now ! |
04-11-2009, 22:26 | #12 (permalink) |
Member: 19723 Status: Offline Thanks Meter: 359 | I used 2 flashes from the support ? Can 2 flashes be wrong ? I tried to flash it with another box and I get "write error" . I will post the names on monday . Thanx ! |
04-12-2009, 18:16 | #13 (permalink) | |
It may be that 2 files from support area has new structure and as a result we can see problem with imei. Please, post here exact file names so we will be able to double check it. | |
04-13-2009, 10:50 | #14 (permalink) |
Member: 19723 Status: Offline Thanks Meter: 359 | S320X-2AKPNL1_XH16AB12_JRD23_07A_PCB01_GPRS_MT6223_S00.M AUI_07A_W07_36_SP1_V20_2008-06-20_En_Fr_Es_It_De_simfree.B0M.bin S320X-2ATLES1_XH16BJ20_JRD23_07A_PCB01_GPRS_MT6223_S00.M AUI_07A_W07_36_SP1_V20_2008-08-21_En_Cn_Cn_simfree.B0M.bin These are the files . Thanx ! |
Alctel s320x no screen after flash | .:==di@bila==:. | Infinity-Box | 11 | 08-28-2009 02:43 |
S320x problem :::ANSWERED::: | usernome | PolarBox 3 | 16 | 05-18-2009 10:57 |
Alcatel-S320X unlocked | souheilh | Infinity-Box | 0 | 03-26-2009 18:11 |
S320x unlocked whit infinitiy | oMeR_Rasheed | Infinity-Box | 5 | 01-14-2009 20:07 |
