06-22-2009, 17:33 | #1 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Dominican Republic Age: 49
Member: 92317 Status: Offline Sonork: 100.1591991 Thanks Meter: 223 | s521a still lock module v2.77 Device: Alcatel-S521X, S521A Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active "format ffs" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:1203:A003 status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22442200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.F4E2F 4AA.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_17E9313E].rpl identification#1 detection finished device-id: F4E2F4AA identification#1 protocol ver: 05 ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN ver. sw 2: MAUI.06B.W07.28.SP1.V34, C1CE16E8 ffs offset/size: 00C00000/00400000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: enabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... original imei: 01143800021196 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... security area (code #1) calculation... done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S521X,S521A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34__system_log_F4E2F4AA_17E9313E_20 090622-121720.B0X.bin Area: Firmware flash: 01227E22442200:18E59F00000000 Write: Firmware detect device identification#2... detection phase #1... detect device identification#2 finished security area (code #3, part #2) calculation... customization: CD95GD63 customization area adjusted: CD95GD63 done flash: 01227E22442200:18E59F00000000 flash: 01227E22442200:18E59F00000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... ..................security area (code #3, part #1) detecting size... security area (code #3, part #1) detecting parameters... security area (code #3, part #1) encoding... done flash: 01227E22442200:18E59F00000000 flash: 01227E22442200:18E59F00000000 Write: security area (code #3, part #1) security area (code #3, part #1) calculation done Write Done Finalization ... formatting... flash: 01227E22442200:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S521X,S521A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34__system_log_F4E2F4AA_17E9313E_20 090622-122002.B0X.bin Finished, time used: 202 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! this is the new fw that u update but not work |
06-23-2009, 08:48 | #3 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hi, Did you tried to flash phone with this file: S521A-2BCECO1-S20_XD92GD90_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_ 06B_W07_28_SP1_V34_2008-05-30_En_Fr_Es_Pt-BR_It_simfree.B0M.bin |
06-23-2009, 08:49 | #4 (permalink) |
06-23-2009, 13:00 | #5 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Dominica, West Indies Age: 63
Member: 88701 Status: Offline Thanks Meter: 381 | Hi CDMAGSM03 is correct Flashing S521A-2BCECO1-S20_XD92GD90_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_ 06B_W07_28_SP1_V34_2008-05-30_En_Fr_Es_Pt-BR_It_simfree.B0M.bin into a new version S521 will make the LCD not to display..(go black) The new file on support S521A-2BCECO1-S20_XD95GD63_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_ 06B_W07_28_SP1_V34_2009-01-14_En_Fr_Es_Pt-BR_It_simfree.B0M.bin ...Listed as new fixes the LCD ..but its NOT sim free as it is described. This file is for provider SpringMobile SD and asks for NCK |
06-27-2009, 18:38 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, S521A-2BCECO1-S20_XD95GD63_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_ 06B_W07_28_SP1_V34_2009-01-04_En_Fr_Es_Pt-BR_It_simfree file is a simfree. Be sure that you have used latest MModule version (it's really important) for flashing and "format ffs" box was checked during flash process. Waiting for your results. |
06-27-2009, 21:58 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | could you, please, post here more details. S521A-2BCECO1-S20_XD95GD63_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_ 06B_W07_28_SP1_V34_2009-01-04_En_Fr_Es_Pt-BR_It_simfree file is a simfree. Be sure that you have used latest MModule version (it's really important) for flashing and "format ffs" box was checked during flash process. Waiting for your results. |
06-28-2009, 15:16 | #10 (permalink) |
Member: 88701 Status: Offline Thanks Meter: 381 | Good Morning Yes.. im using the latest M Module ..(its important because if you use old module with new firmware you have errors) "Format FFS" box is always checked during flash operations The S521 with new hardware works fine with this new firmware ..its just not simfree as listed. Thanks Team ,smokin |
06-28-2009, 15:24 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, double check that you have used correct file, due to two files in support area is very similar: S521A-2BCECO1-S20-95D_XD95GD63_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_ 06B_W07_28_SP1_V34_2009-01-04_En_Fr_Es_Pt-BR_It_simfree.B0M.bin S521A-2BCECO1-S30-95D_XD95NG62_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_ 06B_W07_28_SP1_V34_2009-01-04_En_Fr_Es_Pt-BR_It.B0M.bin |
06-29-2009, 07:25 | #12 (permalink) | |
Member: 92317 Status: Offline Sonork: 100.1591991 Thanks Meter: 223 | Quote:
thanksss all | |
07-03-2009, 20:10 | #13 (permalink) |
No Life Poster Join Date: Oct 2006
Member: 364992 Status: Offline Thanks Meter: 28 | STILL THE PROBLEM... this version : S521X-2AALCN1-S22-929_XD92BJ91_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_ 06B_W07_28_SP1_V34_2008-05-30_En_CnS_CnT_simfree.B0M.bin is not simfree... phone still locked... lcd is OK.. but is locked.. and this version uploaded 28/jun.. is LCD black... S521A-2BCECO1-S20_XD95GD63_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_ 06B_W07_28_SP1_V34_2009-01-04_En_Fr_Es_Pt-BR_It_simfree.B0M.bin Please upload a new flashfile.. simfree... |
07-04-2009, 21:22 | #15 (permalink) | |
You must download and install latest MModule software. | |
why still cost credit unlock dct4? 30 credit gone, phone still locked | snowtown | Universalbox | 4 | 10-09-2009 15:04 |
J230i All Locks Open Still locked!!!!!! | TheMasterGSM | Sony Ericsson | 5 | 03-01-2007 17:35 |
p910i still lock 4 locks!!!! | miciomao_72 | Sony Ericsson Hardware Repair | 0 | 02-03-2007 19:16 |
U8330I all locks open ,phone still locked ? | TRABEL | LG | 0 | 03-14-2006 14:38 |
e228 still locked after "network lock off" | gorgans | FuriouS II | 7 | 12-22-2004 10:39 |
