S621x check this problem please sir please check this error.i need this my set was dead. COM5 [VCP1] selected module v2.79 Device: Alcatel-S621X, S621A Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:6D03:A001 status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22422200:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... original imei: 35199002146867 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Area: Firmware flash: 01227E22422200:FFFFFF00000000 Write: Firmware error: error# 000000FF error: flash write error: 00000000:00002000 error: no any expected answer error: flash write error: 00000000:00002000 error: wrong answer: 3B error: flash write error: 00000000:00002000 error: wrong answer: 74 error: flash write error: 00000000:00002000 error: wrong answer: DB error: flash write error: 00000000:00002000 error: wrong answer: 3B error: flash write error: 00000000:00002000 error: wrong answer: DB error: flash write error: 00000000:00002000 error: wrong answer: DB error: flash write error: 00000000:00002000 error: wrong answer: 3B error: flash write error: 00000000:00002000 error: wrong answer: DB error: flash write error: 00000000:00002000 error: no any expected answer error: flash write error: 00000000:00002000 |
Before what was set condition it was locked/OK? or Dead this problem comes when u r using pinfinder/battery r not charged/cable problem use power meter instead of battery if problem is solved by this procedure check HW Resold/change Flash chip BR;) UMER |
Yes, I agree with Mr.maplegsm if phone can not be flashed it is need to check phone hardware, f.e. replace or reball flash IC. |
