08-24-2016, 04:56 | #1 (permalink) |
Freak Poster Join Date: Jan 2016 Location: Afghanistan
Member: 2520139 Status: Offline Sonork: masoudsoftware Thanks Meter: 300 | Samsung B110E (SPD) Read Phone Lock Done 3sec ========================= Start ========================= 8/23/2016 / 6:25:22 PM ================================================== ======= Card found: S/N : 28B7318D , v0132 Chinese Miracle II [SPD module] v 1.20 Start at : [8/23/2016 / 6:25:43 PM] Operation : Check/Read Info [ v1.20 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 243 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 ¾B Boot Ok CPU ID : 6530 , FDLStat : 00C0 [0] Flash DIE : 00C8 0060 0017 0000 [0] Flash VEN : GigaDevice , GD25LQ64 [0] Flash CAP : 00800000 Elapsed: 00:00:08 Reconnect Power/Cable! Finish at : [8/23/2016 / 6:25:52 PM] Start at : [8/23/2016 / 6:26:07 PM] Operation : Read User Code [ v1.20 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 243 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 ¿A Boot Ok CPU ID : 6530 , FDLStat : 00C0 [0] Flash DIE : 00C8 0060 0017 0000 [0] Flash VEN : GigaDevice , GD25LQ64 [0] Flash CAP : 00800000 Check data... Can take some time User Code : 2009 Done! Elapsed: 00:00:12 Reconnect Power/Cable! Finish at : [8/23/2016 / 6:26:20 PM] |
