06-04-2011, 13:37 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: On Earth
Member: 332724 Status: Offline Sonork: 100.1605077 Thanks Meter: 231 | Samsung B209 Unlock not Done.Please help me. Here is Log: COM4 [VCP0] selected module v1.54 Device: Samsung-SCH-B209, B309, B319, B619, B339FM operation: Rebuild EFS/NV Phone should be Switched ON ! connecting... Connecting, wait... error: can't activate test mode If phone can not be connected after several tries make this: 1. Insert original sim card in phone 2. Power-On phone 3. go to Menu, press 6 then * and type password 123456 4. go to "Port Map", HKF 5. select "UART1" error: operation failed Finished, time used: 26 sec |
06-04-2011, 16:17 | #2 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: Just Imagine Age: 42
Member: 1191481 Status: Offline Sonork: 1592603 Thanks Meter: 1,373 | Quote:
Check Ur Phone Jack Also May B Damaged Follow These Step's 1. Rebuild 2. Unlock Wbr <<<Megatron>>> | |
06-07-2011, 13:30 | #7 (permalink) |
Member: 332724 Status: Offline Sonork: 100.1605077 Thanks Meter: 231 | I was try in this way also.But there is no luck.I think this is not supported in this Infinity software.With my cable Samsung B309 and other some models are unlock perfectly.But B209 and B159 handsets are not unlocking.I was tried in all ways. |
09-18-2011, 19:07 | #9 (permalink) |
No Life Poster Join Date: Dec 2008 Location: bangladesh
Member: 926902 Status: Offline Sonork: 100.1655575 Thanks Meter: 517 | yes infinity have no perfect solution b209 unlok i try 10 pc but not done cable pc phone jac bt volt all are ok so i mens i it not support |
09-19-2011, 05:08 | #10 (permalink) | |
If You Cant Unlock That Dosen't Mean That Its Not Working You Dind't POsted Any Logs Just Coming And Giving -ve Points Did U Try To Change Ur Cable? Did U Try To Put Ur Phone In HFK Mode? Did You Performed All Operation Without Uim Card? Weather You Are Selecting Proper Port? We Are Helpless For Those Users Who Can't Help Themself You Must Try To Find Whats Going Wrong Wbr <<<Megatron>>> | |
09-25-2011, 11:04 | #12 (permalink) |
No Life Poster Join Date: May 2010 Location: <:D-R-E-A-M-S:>
Member: 1312746 Status: Offline Thanks Meter: 766 | brother it works 100% gauranteed....do one thing use the code given above and then u wil get three options...in all of them select UART and then connect RJ45 cable to the phone and click on unlock it will surely work for you... if you are still facing problem contact me on yahoo i will try to help you out.... my yahoo id is [email protected] and i unlocked one handset today itself with the same procedure...here are the logs COM2 [VCP0] selected module v1.61 Device: Samsung-SCH-B209, B309, B319, B619, B339FM operation: SP-unlock Phone should be Switched ON ! connecting... Connecting, wait... Phone detected, wait... step-1/1 done step-1/2 done step-1/3 done step-1/4 done step-1/5 done step-2 done step-3 done operation finished Finished, time used: 41 sec |
The Following User Says Thank You to rahul_rocks3 For This Useful Post: |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
