11-09-2016, 07:44 | #1 (permalink) |
Registered User Join Date: Dec 2015 Location: Chittagong, Bangladesh
Member: 2506300 Status: Offline Thanks Meter: 345 | SAMSUNG E2202 Format Done And Read Done Just 1 click Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 12 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 0000 [0] Flash DIE : 00EF 0060 0018 0000 [0] Flash VEN : Winbond , W25Q128 [0] Flash CAP : 01000000 [1] Flash DIE : 00EF 0060 0018 0000 [1] Flash VEN : Winbond , W25Q128 [1] Flash CAP : 01000000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Operation : Read FullFlash [ v1.22 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 12 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 0000 [0] Flash DIE : 00EF 0060 0018 0000 [0] Flash VEN : Winbond , W25Q128 [0] Flash CAP : 01000000 [1] Flash DIE : 00EF 0060 0018 0000 [1] Flash VEN : Winbond , W25Q128 [1] Flash CAP : 01000000 Read Flash Content Read Ok , collect info Platform : MOCOR_W12.15.01_EtonDS_R2.7.1_Debug sc6530_samsung_EtonDS_SWA ExtInfo : LevelofLock 00000000 00000000 Project : SC6530_SAMSUNG HWInfo : SC6530_EtonDS Compile : 02-01-2013 16:45:25 Set FileInfo : Model Vendor : E2202 Model Name : SAMSUNG E2202 ExtInfo Data : ENG Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6530_SAMSUNG_020 00000_MOCOR_W12.15.01_EtonDS_R2.7.1_Debug_sc6530_s amsung_EtonDS_SWA_02012013164525_ENG__E2202-SAMSUNG E2202.bin Done! Elapsed: 00:02:15 Reconnect Power/Cable! |
